Creating a custom hatch pattern :)
Hello everyone!
I am trying to figure out this pattern:
My goal is to create this cross pattern by creating a pat file.
 I have tried and tried, but haven't seen a satisfying result. So far I've come up with this:
As you can see, the trouble I am having is figuring out the vertical lines in order to have the boxed up cross figure that I am wanting. If anyone could please help, I would gladly appreciate it.
Thank you for your time.
-Montanov
marko_ribar
Here you are :
*htch, htch
90.00000000,0.37500000,0.00000000,0.00000000,1.00000000,0.12500000,-0.87500000
180.00000000,0.37500000,0.12500000,0.00000000,1.00000000,0.25000000,-0.75000000
90.00000000,0.12500000,0.12500000,0.00000000,1.00000000,0.12500000,-0.87500000
180.00000000,0.12500000,0.25000000,0.00000000,1.00000000,0.12500000,-0.87500000
0.00000000,0.12500000,0.37500000,0.00000000,1.00000000,0.25000000,-0.75000000
270.00000000,0.37500000,0.37500000,0.00000000,-1.00000000,0.12500000,-0.87500000
0.00000000,0.37500000,0.25000000,0.00000000,1.00000000,0.25000000,-0.75000000
90.00000000,0.62500000,0.25000000,0.00000000,1.00000000,0.12500000,-0.87500000
0.00000000,0.62500000,0.37500000,0.00000000,1.00000000,0.25000000,-0.75000000
90.00000000,0.87500000,0.37500000,0.00000000,1.00000000,0.25000000,-0.75000000
180.00000000,0.87500000,0.62500000,0.00000000,1.00000000,0.25000000,-0.75000000
90.00000000,0.62500000,0.62500000,0.00000000,1.00000000,0.12500000,-0.87500000
180.00000000,0.62500000,0.75000000,0.00000000,1.00000000,0.25000000,-0.75000000
270.00000000,0.37500000,0.75000000,0.00000000,-1.00000000,0.12500000,-0.87500000
180.00000000,0.37500000,0.62500000,0.00000000,1.00000000,0.25000000,-0.75000000
270.00000000,0.12500000,0.62500000,0.00000000,-1.00000000,0.25000000,-0.75000000
90.00000000,0.62500000,0.00000000,0.00000000,1.00000000,0.12500000,-0.87500000
0.00000000,0.62500000,0.12500000,0.00000000,1.00000000,0.25000000,-0.75000000
90.00000000,0.87500000,0.12500000,0.00000000,1.00000000,0.12500000,-0.87500000
0.00000000,0.87500000,0.25000000,0.00000000,1.00000000,0.12500000,-0.87500000
270.00000000,0.37500000,1.00000000,0.00000000,-1.00000000,0.12500000,-0.87500000
180.00000000,0.37500000,0.87500000,0.00000000,1.00000000,0.25000000,-0.75000000
270.00000000,0.12500000,0.87500000,0.00000000,-1.00000000,0.12500000,-0.87500000
180.00000000,0.12500000,0.75000000,0.00000000,1.00000000,0.12500000,-0.87500000
270.00000000,0.62500000,1.00000000,0.00000000,-1.00000000,0.12500000,-0.87500000
0.00000000,0.62500000,0.87500000,0.00000000,1.00000000,0.25000000,-0.75000000
270.00000000,0.87500000,0.87500000,0.00000000,-1.00000000,0.12500000,-0.87500000
0.00000000,0.87500000,0.75000000,0.00000000,1.00000000,0.12500000,-0.87500000
HTH., M.R.
Marko Ribar, d.i.a. (graduated engineer of architecture)
hugha
Try this:
; Written by HatchKit Team Edition
; HatchKit Team Edition (c)1990-2019 Cadro Pty Ltd
; www.hatchkit.com.au/
;-Date : 2020-05-05
;-Time : 18:21:41
;-HatchKit Team Edition Version : 3.1.11.2776
;-HatchKit Team Edition Output Filetype : AutoCAD format
*htch,htch
90,0.125,0.375,0.5,0.5,0.25,-0.75
0,0.625,0.625,0.5,0.5,0.25,-0.75
0,0.125,0.625,0.5,0.5,0.25,-0.75
0,0.375,0.75,0.5,0.5,0.25,-0.75
90,0.875,0.375,0.5,0.5,0.25,-0.75
0,0.375,0.25,0.5,0.5,0.25,-0.75
0,0.625,0.375,0.5,0.5,0.25,-0.75
90,0.375,0.625,0.5,0.5,0.125,-0.875
90,0.375,0.25,0.5,0.5,0.125,-0.875
90,0.625,0.25,0.5,0.5,0.125,-0.875
90,0.625,0.625,0.5,0.5,0.125,-0.875
Careful hand optimisation is possible but probably unnecessary
hth,
Hugh Adamson
Kent1Cooper
As so often when these things come up, I think this can be much simpler.  I don't have time to fire up AutoCAD to test [I need to leave soon], but see whether this does it:
0, 0,0, 0,.25, .25,-.25 ; tops/bottoms of all "arms"
0, .25,-.125, 0,.5, .25,-.25 ; tops/bottoms of all "heads" & "feet"
90, 0,0, .5,.5, .25,-.125,.125,-.25,.125,-.125 ; left "arm" ends, right "head"/"foot" sides
90, .75,0, .5,.5, .25,-.125,.125,-.25,.125,-.125 ; right "arm" ends, left "head"/"foot" sides
The origin is at the lower left corner of a left "arm."
Kent Cooper, AIA
Kent1Cooper
@Kent1Cooper wrote:
....  I don't have time to fire up AutoCAD to test ....
Back on, tested it, it works.
Kent Cooper, AIA
serkancavuslar
Hi, @montanov661 @Kent1Cooper @hugha @marko_ribar
Serkan ÇAVUŞLAR
CplCAD / Türkiye
serkancavuslar
@Anonymous  Hi, why no solution accepted
Serkan ÇAVUŞLAR
CplCAD / Türkiye
