Creating a 3-point rectangle.
Browning_Zed
Browning_Zed
I need a lisp for creating 3 point rectangle. I know about Lee Mac's program, but his program contains an important flaw. If you try to build a rectangle by points primitives that have different Z-coordinates, the result is not a rectangle, but a rhombus. Advise if Lee Mac's lisp can be modified so that he builds a rectangle without considering the height of the points? Or maybe there is some other working lisp?
doaiena
If Lee's code works for you, you could just zero out the Z values of your picked points.
The code starts with picking points:
(setq pt1 (getpoint "\nSpecify 1st point: "))
(setq pt2 (getpoint "\nSpecify 2nd point: " pt1))
After the points are set, you could zero the Z values of those points
(setq pt1 (list (car pt1) (cadr pt1) 0.0))
(setq pt2 (list (car pt2) (cadr pt2) 0.0))
Browning_Zed
Yes, it works great.
