create parcel by lisp(no dialog box showing up)
mehdi-guida
Message 1 of 12
mehdi-guida
Hi
i want to make parcels by existing objects by LISP. but i could not  deactivate the windows and dialog boxes. how can i make parcels by lisp?
Replies (11)
Message 2 of 12
dlanorh
Post the lisp that failed, sometimes there are ways around dialog boxes. Failing that post an example drawing showing before and after so everyone knows what you are trying to achieve and with what.
I am not one of the robots you're looking for
Message 3 of 12
Sea-Haven
Are you talking about CIV3D parcels ? If so there may be sample code available in Vlisp, VBA or .net, I think I have seen it mentioned.
Message 4 of 12
Sea-Haven
Just search your Autodesk directory for parcelsample.dvb and open it up in VBAMAN then will expose all the method to use in VLISP.
Message 5 of 12
mehdi-guida
attdia can help for not showing dialog boxes in a Lisp file.
but it doesn't work for 'CreateParcelFromObjects'.
how can i deactivate dialog boxes to use 'CreateParcelFromObjects' in a Lisp program?
Message 6 of 12
Sea-Haven
You have to via a program select objects, then again create parcels, all being done from a equivalent to the default "createparcels" but with out the dcl.
That is what is in the VBA sample code.
Message 7 of 12
mehdi-guida
maybe i didn't understand correctly.
suppose the selection set named "S1" include objects for making parcels.
what is the lisp codes that make parcels by 'S1' (with no dcl)?
Message 8 of 12
Ajilal.Vijayan
try this code
The below code is based on the solution from here
(defun c:test ( / C3D *acad* prodstring C3Ddoc sites site parcelsegments s i e )
;;;https://forums.autodesk.com/t5/civil-3d-forum/lisp-to-create-civil-3d-surface-from-point-file/m-p/6342001#M302637
  (setq	C3D	   (strcat "HKEY_LOCAL_MACHINE\\"
			   (if vlax-user-product-key
			     (vlax-user-product-key)
			     (vlax-product-key)
	C3D	   (vl-registry-read C3D "Release")
	verstring  (substr C3D
			   1
			   (vl-string-search
			     C3D
			     (+ (vl-string-search "." C3D) 1)
	prodstring (strcat "AeccXUiLand.AeccApplication." verstring)
    (if (and (setq *acad* (vlax-get-acad-object))
	   (setq C3D (vla-getinterfaceobject *acad* prodstring))
	   (setq C3Ddoc (vla-get-activedocument C3D))
	   (setq sites (vlax-get C3Ddoc 'sites))
	   );and
	   (progn
	   (if (> (vlax-get sites 'count) 0)
		(progn
			(setq site (vla-item sites 0));;<-- using the first site,(Change the number Zero to use different Site name)
			(setq parcelsegments (vlax-get site 'ParcelSegments))
			(if (setq s (ssget))
			(progn
				(setq i (1- (sslength s)))
				(while (<= 0 i)
					(setq e (ssname s i)
						  i (1- i)
					(vlax-invoke-method parcelsegments 'AddFromEntity (vlax-ename->vla-object e) T)
		);if
		(vlax-release-object sites)
		(vlax-release-object C3Ddoc)
		(vlax-release-object C3D)
		);progn
		(princ "**Sites not found, at least one site is required**")
	   );if
	  );progn
	);if
	(princ)
);defun
Message 9 of 12
mehdi-guida
Thank you so much
can i use that for making alignments?
Message 10 of 12
Sea-Haven
Your missing the point about what I am saying there is multiple sample code for creating different objects within CIV3D. Like Pipes, alignments, points, surfaces etc. Its in the Sample directory c:\program files\Autodesk …….
I wrote code for description key sets as there was no IMPORT or multiple change function.
I also have replaced the Toolbox selecting surface settings with icons much easier. Getting into CIV3d is not a quick thing.
Message 11 of 12
mehdi-guida
Thank you
How can i know more about your codes and programs?
Message 12 of 12
Sea-Haven
Have a look at this load the 2 menu files. It has read me etc. For contours need you contour style names.
