Create new layout tabs and assign mspace coords
neaton
Advisor Advisor
Message 1 of 9
neaton
I am trying to copy an existing layout tab multiple times, name them in a consecutive order and set the mview to specific coordinates in model space. Everything is working well, except that it is creating increasingly multiple viewports for each new layout. Layout 2 has 1 viewport, Layout 3 has 2 viewports, Layout 4 has 3 viewports...
I don't do much LISP programming and my routines are usually one-liners so I am sure there is a much easier way to do this. Attached is the dwg after I run the attached .lsp file. Thanks for any help!
Nancy
Replies (8)
Message 2 of 9
dbhunia
Try This.....
Do not forget that you are copying each Layout and creating viewport in new created Layout.......That's the reason for getting multiple viewport....
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Message 3 of 9
maratovich
See this solution on the forum:
https://forums.autodesk.com/t5/autocad-forum/create-multi-layouts-in-paper-space/m-p/8453051#M960067
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
Message 4 of 9
dbhunia
Sorry I forget to attach the file.......
Debashis Bhunia
Message 5 of 9
neaton
Thanks, @maratovich. That is the post that started me thinking that the solution shouldn't be that hard. Since I am teaching myself LISP I thought it would be a good problem to tackle. Obviously, I still have a lot to learn since I couldn't get it to work.
Nancy
Message 6 of 9
neaton
Thanks, @dbhunia. That works perfectly. Now I just have to figure out why the additional if statement is required. I guess my understanding of how the while and if statements work is incorrect. Thanks for the help!
Nancy
@dbhunia wrote:
Try This.....
Message 7 of 9
maratovich
Good thing you have found a temporary solution.
Do not forget this forum.
When your lisp stops working, you will return here.
www.kdmsoft.net
Message 8 of 9
ВeekeeCZ
@neaton wrote:
... Now I just have to figure out why the additional if statement is required. I guess my understanding of how the while and if statements work is incorrect. ....
Hi @neaton, I wouldn't think that layouts are the typical thing to start learning with..., but you did it pretty well!
I would say that it's not really incorrect while that caused all the trouble.... but, there are some things that you should consider to make your code better readable.
- do you really need 2 counters?
- do you need so many variables?
- are the variable names clear enough that still need to be explained in commentaries...
- isn't there a better type of loop for this purpose? The while is good if you prior don't know how many iterates you will need.
Spoiler.
(defun c:NVXXI ( / mll mur dst ang pfr pll pur idx)
  (command )
  (setq mll '(0 0)
	mur '(86 66)
	dst  130
	ang  0.
	prf "F"
	pll '(0.95 0.7)
	pur '(9.5633 7.3)
	idx 1
  (repeat 4
    (if (= idx 1)
      (command "tilemode" 0
	       "pspace"
	       "mview" pll pur)
      (command "layout" "Copy"
	       (strcat prf (itoa (1- idx)))
	       (strcat prf (itoa idx))
	       "layout"
	       "Set" (strcat prf (itoa idx))))
    (command "mspace"
	     "zoom"
	     (polar mll ang (* (1- idx) dst))
	     (polar mur ang (* (1- idx) dst))
	     "tilemode" 0
	     "pspace")
    (setq idx (1+ idx)))
  (princ)
Message 9 of 9
neaton
@ВeekeeCZ thanks for the logic lesson; I knew there was a cleaner way to do this.
Nancy
