create MLeader in LISP
Hello!
I am trying to solve the following task in lisp:
In my code I can calculate a Text, the position of the Text and the end-point of a MLeader line I would like to have.
How can I now create this MLeader object (if I go for (command "_mleader" pointA pointB) I get code 0xC0000005)?
Greetings
ВeekeeCZ
Certainly you can use what you suggest. Not sure what's your question.
(command "_mleader" pause pause "note")
if you need an ename of the mleader just created, use
(setq ent (entlast))
devitg
Show your LISP ..  ant a sample.dw , as you need the mleader to be
So what I am basically trying to do is:
(setq pointA (list 0 0 0))
(setq pointB (list 5 5 0))
(command "_mleader" pointA pointB _Y "test")
This already throws my exception in an empty drawing.
dlanorh
I'm not suprised check the item highlighted red above.
1. What is it for?
2. Why is it not in quotes "_Y"?
I am not one of the robots you're looking for
devitg
From it
(command "_mleader" pause pause text )
