Create list of Layergroups
niels_dedecker
niels_dedecker
Greetings,
i'm trying to create a lisp to print multiple pdf's from one drawing based on the amount of Layergroups.
they are old drawings that contain several grouplayers wich each containing a component:
"base layergroup" is the group that contains stuff like the frame and logo of the template and the others are seperate components.
so the main goal is to freeze all, thawn "base layergroup", thawn "1" and print; next  freeze all, thwan "base layergroup", thawn "1A" and print; ... .
the major problem is that all the drawings i recieve all have layergroups but rarly the same name aside from "base layergroup", so i'm trying to first extract a list of layergroups and starting the loop of printing till all layergroups are done.
i've scoured allot of forums and i did find something from Mac Lee to generate a list of layergroups but i'm unable to get it working. i've tried allot myself but i'm unable to find the location of these layergroups...
ronjonp
It would help to upload a sample drawing and the code that you found from Lee.
niels_dedecker
My appologies, i'm not used to posting on forum myself 🙂
In the attachment you can find a very trimmed version of a simple drawing i recieve and this is the code that i found from Lee:
(defun LM:grouplayerfilters nil
   (   (lambda ( foo ) (foo (entget (cdr (assoc 330 (entget (tblobjname "layer" "0")))))))
       (lambda ( enx / dic itm rtn )
           (and (setq dic (cdr (assoc 360 (member '(102 . "{ACAD_XDICTIONARY") enx))))
                (setq dic (cdr (assoc -1  (dictsearch dic "aclydictionary"))))
                (while (setq itm (dictnext dic (not itm)))
                    (if (= "AcLyLayerGroup" (cdr (assoc 1 itm)))
                        (setq rtn (cons (cons (cdr (assoc 300 itm)) (foo itm)) rtn))
           (reverse rtn)
komondormrex
i can't found no layer group in attached sample.
niels_dedecker
Maybe it's because i use Autocad Mechanical ? "AMLAYERGROUP" should give you the selection
sachindkini
niels_dedecker
Thanks for the reply Sachinidkini but i've found that one aswell but that works for Layer filters or something.
Apparently the Layergroups i get from command AMLAYERGROUP is something different 😞
