create layout based on polygons in model space
CNinBC
Message 1 of 8
CNinBC
We have been asked to create 8.5X11 drawings for each property along our roadwork project to show the homeowner the property impacts. there are hundreds of properties. is there a quick and easy way to create layouts by selecting the property line polygons in the model space and fit each polygon into the layout viewport template?
Thanks.
Replies (7)
Message 2 of 8
pendean
Community Legend
Community Legend
Not exactly what you asked for, but how about this freebie in the interim from the Autodesk App Store https://apps.autodesk.com/ACD/en/Detail/Index?id=2430986909281925511&appLang=en&os=Win32_64
Message 3 of 8
maratovich
Try it - AutoViewport
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
Message 4 of 8
CodeDing
@CNinBC ,
If neither of the above mentioned items are what you're looking for, then could please post an example dwg with what you start with and your desired end state?
Best,
~DD
Message 5 of 8
CNinBC
thanks @pendean , @maratovich & @CodeDing for your suggestions, however, those are not exactly what I wanted,  please see attached sample drawing, I wish by selecting the property line polygons, I can use the layout template in the same drawing to create multiple layouts to show each property.
Message 6 of 8
CodeDing
@CNinBC ,
Maybe this?
(defun c:V4P ( / tmp ssVP tab ssPL scaleList sweetRngMax sweetRngMin sweetRngAvg vpVal vpArea n cnt ePL plArea goodVal bestVal bestScale pref eVP)
;Viewports for(4) Properties
(cond
  ((= 1 (getvar 'TILEMODE))
    (setq tmp "\nYou must start on a layout tab you wish to use as a template.") (prompt tmp) (alert tmp) (exit))
  ((not (setq ssVP (ssget "_X" (list '(0 . "VIEWPORT") (cons 410 (setq tab (getvar 'CTAB))) '(-4 . "<NOT") '(69 . 1) '(-4 . "NOT>")))))
    (setq tmp "\nNo viewports were found on your template layout tab.") (prompt tmp) (alert tmp) (exit))
  ((> (sslength ssVP) 1)
    (setq tmp "\nThere can only be 1 viewport on your template layout tab.") (prompt tmp) (alert tmp) (exit))
  ((not (setq ssPL (ssget "_X" '((0 . "LWPOLYLINE") (8 . "PROPERTY LINES")  (70 . 1) (410 . "Model")))))
    (setq tmp "\nNo closed PROPERTY LINES were found in model space.") (prompt tmp) (alert tmp) (exit))
);cond
(if (> (getvar 'CVPORT) 1) (command "_.PSPACE"))
(setq scaleList '(10 25 50 100 150 200 250 500 1000 1250 1500 1750 2000 3000 5000)
      sweetRngMax 0.85
      sweetRngMin 0.6
      vpVal 1000 ;<-- 1 Model Space unit equals [vpVal] Paper Space units
      sweetRngAvg (* 0.5 (+ sweetRngMax sweetRngMin))
      vpArea (* (getpropertyvalue (ssname ssVp 0) "Height") (getpropertyvalue (ssname ssVp 0) "Width"))
      vpVal (* vpVal vpVal)
);setq
(setq n 1)
(repeat (setq cnt (sslength ssPL))
  (setq ePL (ssname ssPL (setq cnt (1- cnt)))
	plArea (* vpVal (getpropertyvalue ePL "Area"))
	goodVal nil
	bestVal nil
	bestScale nil
  );setq
  (foreach scale scaleList
    (if (< 0.0 (setq goodVal (/ (* plArea (/ 1.0 scale)) (* vparea scale))) 1.0)
      (if (> (- sweetRngAvg (abs (- sweetRngAvg goodVal)))
	     (- sweetRngAvg (abs (- sweetRngAvg (if bestVal bestVal (setq bestScale scale bestVal goodVal))))))
	(setq bestVal goodVal bestScale scale)
      );if
    );if
  );foreach
  (if bestScale
    (progn
      (setq pref "PROP ")
      (while (member (strcat pref (itoa n)) (layoutlist)) (setq n (1+ n)))
      (command "-LAYOUT" "copy" tab (strcat pref (itoa n)))
      (setvar 'CTAB (strcat pref (itoa n)))
      (setq eVP (ssname (ssget "_X" (list '(0 . "VIEWPORT") (cons 410 (strcat pref (itoa n))) '(-4 . "<NOT") '(69 . 1) '(-4 . "NOT>"))) 0))
      (command "_.MSPACE") (command "_.ZOOM" "o" ePL "") (command "_.PSPACE")
      (setpropertyvalue eVP "CustomScale" (/ 1.0 (* 0.001 bestScale)))
      (setq n (1+ n))
    );progn
  ;else
    (prompt "\nNo acceptable scale found for property.")
  );if
);repeat
(prompt "\nV4P Complete.")
(princ)
);defun
Best,
~DD
Message 7 of 8
CNinBC
thanks @CodeDing , that works great.
Message 8 of 8
saravanan_shanmugam
Community Visitor
Community Visitor
it's not working For me, can please look into my attched dwg
