Create installer
Create installer
carlos_m_gil_p
Create installer
carlos_m_gil_p
Hello boys how are you.
I wanted to check if someone would have a tutorial to create an installer.
I have my .fas and .vlx files.
But I want to create an installer and not do it manually.
I have seen that with inno setup it can be done but I can not create it to work with my files and autocad, because after installed, they should run when using the commands.
Thank you.
AutoCAD 2026.1.1
Visual Studio Code 1.105.1
AutoCAD AutoLISP Extension 1.6.3
Windows 10 - 22H2 (64 bits)
_gile
You should have a look at the Autodesk Autoloader mechanism which makes application deployment much more easy.
If you want to create an installer, using the Autoloader mechanism, the installer only have to put the package (.bundle folder) in one of the Autodek\ApplicationPlugins folder.
Gilles Chanteau
GileCAD
GitHub
carlos_m_gil_p
Hi. How have you been.
Thanks for your answer, I will study well that and anything I tell you.
Greetings.
AutoCAD 2026.1.1
