Create folder in "C" Partition
hanywillim
Message 1 of 10
hanywillim
i work with main lisp to create a folder on desktop and save drawings in it , now i want to create this folder in C partition:
(setq desktop-dir (strcat (getenv "USERPROFILE") "\\Desktop"))
(vl-mkdir (strcat desktop-dir "\\Cleaned Drawings\\"))
(command "_.SAVEAS" "" (strcat desktop-dir "\\Cleaned Drawings\\" (nth n Files_Folder)) "_Yes")
 Now need to create the folder in this path:
C:\My folder\Cleaned Drawings
Thanks in advance
Replies (9)
Message 2 of 10
paullimapa
(setq desktop-dir "C:\\My Folder")
Paul Li
IT Specialist
@The Office
Message 3 of 10
hanywillim
i run the lisp but get this error:
Path does not exist: C:\My Folder\Cleaned Drawings\
Please verify the correct path was given.
and checked partition "C" there is no folders created yet
i think maybe need a permission to create folder in C or it is something else?
Message 4 of 10
paullimapa
You can test to see if this fails to create folder by pasting directly onto AutoCAD command line. Like you stated you may not have permissions to create this on C: since it’s not inside your windows profile
Paul Li
IT Specialist
@The Office
Message 5 of 10
hanywillim
But i need the code to create the "My Folder" if it is not exist
Message 6 of 10
paullimapa
But like you said you may not have permissions to create this on your C: drive
Perhaps another way to test is to run Windows Explorer and see if you’re successful in creating My Folder in C:
Paul Li
IT Specialist
@The Office
Message 7 of 10
Sea-Haven
Just test 1st level. Copy and paste to command line.
(vl-mkdir "C:\\My Folder")
Message 8 of 10
hanywillim
it is work
should i create each folder first by using separated line code like this, or i can create all the path once?
Message 9 of 10
Sea-Haven
I tried to make a big sub directory not working. Looks like mkdir only makes 1 level. Maybe try running Mkdir multi times. The other way is using Shell and you can use the old fashioned DOS command MD your directory.
(command "._shell" "MD d:\\localjobs\\fs\\LCFC3\\DESIGN\\DATA")
Message 10 of 10
Michiel.Valcke
vl-mkdir can only make one directory at the time, feed it a list of directories and loop through it to make deeper paths
You can do something like this:
(defun MakeMultiDir ( lst / dir)
	(foreach x lst
		(if dir
			(setq dir (strcat dir "\\" x))
			(setq dir x)
		(vl-mkdir dir)
	(princ)
(defun c:testmakemultidir ( / )
	(MakeMultiDir (list "c:\\test" "make" "multiple" "directories"))
	(princ)
