create a script listing xref / block used
jim3thornton
jim3thornton
Is it possible to create a script that will scan a set of drawings a list which sheets a specific xref or block has been used?
I would like to script that would identify / list which sheets have various deltas used.
hmsilva
Hi ncjim,
if by 'scan a set of drawings a list which sheets' you mean, access SSM, no is not possible using Auto/Visula LISP.
If it is to scan a .dwg directory, and, for instance, create a .txt file identifying the file/files and tab where a specific xref or block has been used, probably, yes It can be done.
Henrique
jim3thornton
i'm going to try and develop a script that will insert a Delta block and then insert a value into the corresponding custom property in the sheet set manager
