create a new custom linetype
guido_maniglia
Message 1 of 9
guido_maniglia
Can anyone help me create a new linetype like the picture?
I tried to create it from express tools but it doesn't let me select a circle
Thx
Replies (8)
Message 2 of 9
richard_387
It looks like the FENCELINE1 linetype, but without the spaces.
So I copied the FENCELINE1 definition and edited out the spaces
*FENCELINE1,Fenceline circle ----0-----0----0-----0----0-----0--
A,.25,-.1,[CIRC1,ltypeshp.shx,x=-.1,s=.1],-.1,1
*FC1,line with circle ----0-----0----0-----0----0-----0--
A,.25,[CIRC1,ltypeshp.shx,x=-.1,s=.1],1
Message 3 of 9
vladimir_michl
Like this?
*Circle0,Circled ----()----()----()-----()-----
A,4,[CIRC1,ltypeshp.shx,S=.8,X=-.8],4
Vladimir Michl, www.arkance.world  -  www.cadforum.cz
Message 4 of 9
Kent1Cooper
Read about MKLTYPE [@pendean's correction] in Help.  It describes what you can use in the process, and a Circle is not among the options.  But AutoCAD comes with a very similar linetype:  FENCELINE1:
It uses a Shape as the Circle.  If that looks right except for the line being broken at the circles, its definition can certainly be adjusted to cross through them.  And the spacing between instances of the circle [one thing your image doesn't address] can be adjusted.
Or, put in the Shape [it's called CIRC1 in the ltypeshp.shx file], which is among the permitted things you can use in MKLTYPE.
Kent Cooper, AIA
Message 5 of 9
pendean
Community Legend
Community Legend
@Kent1Cooper wrote:
Read about MDLTYPE in Help. ...
MKLTYPE for anyone skimming the excellent reply above.
Message 6 of 9
guido_maniglia
This method doesn't work, you can't select a circle
Message 7 of 9
Kent1Cooper
If by "this method" you mean the MKLTYPE command [since you replied to @pendean, who mentioned only that], as I said, a Circle is not an allowable object to use in MKLTYPE, but a Shape is.  It should work if you put in a CIRC1 Shape [read about the SHAPE command in Help].
Kent Cooper, AIA
Message 8 of 9
CGBenner
@guido_maniglia
Do you still need help with this or did the answer given by @Kent1Cooper help you solve it?
Chris Benner
Message 9 of 9
guido_maniglia
Hi, I've already marked the posts that solved the problem.
