Create a list with 4 real numbers
etilley327KA
etilley327KA
What am I doing wrong here? FC is a global variable from another lisp, with four blocks.
(defun c:wert (/ i e c cl)
(if (= (sslength fc) 4)
(progn
(repeat (setq i (sslength fc))
(setq e (ssname fc (setq i (1- i))))
(setq c (getpropertyvalue e "ELEV2"))
(setq cl (cons (rtos c 2 2) cl))
(print cl)
(prompt "\nMore than one form selected")
(princ)
);end
Kent1Cooper
Does an Attribute with the tag "ELEV2" exist in all the Blocks?
Is 'fc' a selection set, such as the code appears to be designed for, or perhaps a list of entity names instead?
Define "wrong."  What are you getting?  Are there any error messages?  Etc., etc.
Kent Cooper, AIA
etilley327KA
FC is a selection set that all have the attribute "ELEV2". I get bad argument type: numberp: "156.20" : error#2. There are four strings "156.20" "156.18""156.16" "156.13".
Kent1Cooper
If 'c' is an Attribute value, it's already a text string, so you can't apply (rtos) to it.  In your final 'cl' list, do you want them as text strings or as numbers?  Either way, if you want them to 2 decimal places, do they [or might they sometimes] have a different number of decimal places as Attribute values?
If, for example, you want them as strings without changing their number of decimal places, then this:
should be just:
(setq cl (cons c cl))
Kent Cooper, AIA
etilley327KA
So how might I convert this selection set to real numbers?
Kent1Cooper
Read about the (atof) and possibly (distof) functions.
Kent Cooper, AIA
etilley327KA
Didn't know about that, thanks.
