Create a attributed table based on another block's attribute.
jotaferrer
Message 1 of 13
jotaferrer
Hello y'all, here I go again...
I need to create a table-like based on attributed blocks. It has to be that way because it's easier for me to check the data in excel.
So far, I "attout" the attributes and "attin" them in a table I have. But I want to do it in another way. It could be done in steps because I think this will be a tricky and hard lisp. I don't even know how to start, but there it goes:
If I could at least insert the block "TKTOP1" of the table using my csv file, it would be awesome!
I can totally change the attributes names if it's needed though.
Replies (12)
Message 2 of 13
pbejse
Where is the CSV file @jotaferrer ?
Message 3 of 13
jotaferrer
Sorry, I forgot to post the csv files...
Message 4 of 13
pbejse
To be clear, you wanted to insert a table [ "TKTOP1" ]
Populate the table values [ "TKLINE" ]  from the CSV file and not from the existing blocks [ "tanklabr" [ on the drawing?
OR populate a table using the existing blocks of the current drawing?
Message 5 of 13
jotaferrer
@pbejse
It'd be easier if I could to it right from the block inserted in the drawing, but the point is in some cases there are more than one block with all the same attributes. That's something I need to avoid.
So, to be clear, I want to insert the "TKTOP1" and populate TKLINE from the CSV I get from the drawing because I can not have repeated data in my table 😕
Message 6 of 13
pbejse
TKLINE csv/txt file basically has the same values  found on TKTABLE csv/txt file.
Are you wanting to user to select both or TKTABLE file is enough?
OR
The only value needed from TKTABLE is the values for TKTOP1 and ignore the rest, the actual values are TKLINE block are from TKLINE file?
Message 7 of 13
jotaferrer
In fact, this is just a sample of what I need. When I work in the whole drawing I have several lines that I need to set by deck and board, that's why the values seems to be repetitive.
Let me show CSVs files when the dwg is ready...
Maybe I'm confusing things:
1 - I insert the "tanklabr" block and fill the values manually.
2 - I attout every "tanklabr" and open the file "A" in excel.
3 - I insert "TKTOP1" and as many "TKLINE" and I need.
4 - I attout every "TKTOP1" and "TKLINE" in another "B" file and open it in excel.
5 - I fill the "B" file with the values from "A" file.
6 - I attin the "B" file to replace the attributes of "TKTOP1" and "TKLINE"
Let me know if I was clear enough, please
Message 8 of 13
pbejse
I opened a real can of worms with that last question.
Now that we have more than one TKTOP1 data on that TKTABLE_Final file, are you saying now there are more than one table to insert?
If thats a yes, What Tkline data belongs to what TKTOP1 table?  and from what file?
I assume this are referring to the same data
TKTABLE_Final file
Line 107 | from Col 58 value is WINDLASS OIL TANK FILL WIND O F PIPE 01 DECK STBD
TKLINE final file
Line 44 | from Col 39 value is  WINDLASS OIL TANK FILL WIND O F PIPE 01 DECK STBD
Or are you building one central table for all values from tanklabr , if YES whichTKTOP1 from TKTABLE_Final data will be use for TKLINE block or is it from TKLINE final file?
EDIT: I did not see your edited response there
Message 9 of 13
jotaferrer
Man, I'm handling with these worms for too long also haha
I'm trying to think in a simple way to solve this...
What if we forget about CSV files and:
"ssget _X" "tanklabr"
insert a "TKTOP1" for Main Deck
insert a "TKLINE" and fills it with "tanklabr" filtered values by the TYPE > DECK > BOARD) until it ends
after that a "TKTOP1" for 01 Deck
insert a "TKLINE" and fills it with "tanklabr" filtered values by the same TYPE > DECK > BOARD) and so on
I can organize its visual manually, this is not a big problem. The main thing for me is what I said above, forget about the other big worms I've said before xD
Message 10 of 13
pbejse
Sold!  We will do it that way then.
Message 11 of 13
jotaferrer
Yay! Thanks for your big patience xD this is really freaking me out!!!
Message 12 of 13
pbejse
Here you go
Command: Labelinglist
Enter Type [Manhole/Pipe]: P
Pick table insertion point
Enter Type [Manhole/Pipe]: M
Refer to attached lisp file [ LabelingList.lsp ]
HTH
Message 13 of 13
jotaferrer
Thank you so much! I'm going to spend a lot of time studying this awesome lisp, dude! You roooock!
