Count amount of annotation scales in XRefs
jakob_holmquist
jakob_holmquist
Hi!
I am trying to create a lisp that gets in some way accesses all Annotation scales that each XRef contains. I have this lisp below that counts the amount of annotation scales in the current drawing, but have not succeeded in getting access to any XRef's scale list, either by using (dictsearch (namedobjdict) "ACAD_SCALELIST")  since it only works with the active drawing or by any other method. Is it even possible?
(defun GetScaleListEntities (/ lst item)
  (setq lst nil)
  (foreach item	(dictsearch (namedobjdict) "ACAD_SCALELIST")
    (if	(= 350 (car item))
      (setq lst (cons (cdr item) lst))
    ) ;end if
  ) ;end foreach
  lst
komondormrex
hey there,
check the code following
(defun c:get_xrefs_scale (/ insert_sset scale_list acad_dbx_object)
	(if (setq insert_sset (ssget "_x" '((0 . "insert"))))
		(progn
			(print "This drawing")
			(vlax-map-collection (vla-item (vla-get-dictionaries (vla-get-activedocument (vlax-get-acad-object))) "acad_scalelist")
				'(lambda (dictionary) (setq scale_list (append scale_list (list (cdr (assoc 300 (entget (vlax-vla-object->ename dictionary))))))))
			(print scale_list)
			(terpri)
			(vlax-map-collection (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))
				'(lambda (insert) (if (minusp (vlax-get insert 'isxref))
									(progn
										(setq scale_list nil)
										(setq acad_dbx_object (vlax-create-object (strcat "objectdbx.axdbdocument." (substr (getvar 'acadver) 1 2))))
						   				(vla-open acad_dbx_object (print (vlax-get insert 'path)))
						   				(vlax-map-collection (vla-item (vla-get-dictionaries acad_dbx_object) "acad_scalelist")
										(print scale_list)
										(terpri)
										(vlax-release-object acad_dbx_object)
	(princ)
wispoxy
xref method...
(defun count-annotation-scales-in-xrefs ()
  (let ((xrefs (vla-get-Xrefs (vla-get-ActiveDocument (vlax-get-acad-object))))
        (scale-count 0))
    (vlax-for xref xrefs
      ;; Open the Xref file in the background
      ;; Access the named object dictionary of the Xref
      ;; Count the annotation scales
      ;; Increment scale-count
    ;; Return the total count of annotation scales
    scale-count
komondormrex
ai-lisped)))
wispoxy
😅Ya just realized the function wasn't there. Hold on, hold on. I need to start testing these first.
