Copy Values From one Attribute Block to Selected Block Using Prompt
aamos
Message 1 of 21
aamos
I found the lisp routine below and I changed vla-get-tagstring to vla-get-promptstring and I get the error... ActiveX Server returned the error: unknown name: PromptString.
The presence of duplicate attribute tags with the blocks I'm working with requires me to opting to use the attribute prompt to identify the attributes.
Please help me to understand what can be done to copy Copy values from one Attribute block to selected block using prompt.
(defun c:MAV (/ AT:GetSel atts ss i ass)
;; Match Attribute Values
;; Alan J. Thompson, 2017.01.31
(defun AT:GetSel (meth msg fnc / ent)
;; meth - selection method (entsel, nentsel, nentselp)
;; msg - message to display (nil for default)
;; fnc - optional function to apply to selected object
;; Ex: (AT:GetSel entsel "\nSelect arc: " (lambda (x) (eq (cdr (assoc 0 (entget (car x)))) "ARC")))
;; Alan J. Thompson, 05.25.10
(while
(progn (setvar 'ERRNO 0)
(setq ent (meth (cond (msg)
("\nSelect object: ")
(cond ((eq (getvar 'ERRNO) 7) (princ "\nMissed, try again."))
((eq (type (car ent)) 'ENAME)
(if (and fnc (not (fnc ent)))
(princ "\nInvalid object!")
ent
(if (and (AT:GetSel entsel
"\nSelect source attributed block: "
(lambda (x / d)
(if (and (eq (cdr (assoc 0 (setq d (entget (car x))))) "INSERT")
(eq (cdr (assoc 66 d)) 1)
(setq atts (mapcar (function (lambda (a) (cons (vla-get-promptstring a) (vla-get-textstring a))))
(vlax-invoke (vlax-ename->vla-object (car x)) 'GetAttributes)
(progn
(princ "\nSelect destination attributed block(s): ")
(setq ss (ssget "_:L" '((0 . "INSERT") (66 . 1))))
(repeat (setq i (sslength ss))
(foreach a (vlax-invoke (vlax-ename->vla-object (ssname ss (setq i (1- i)))) 'GetAttributes)
(if (setq ass (cdr (assoc (vla-get-promptstring a) atts)))
(vla-put-textstring a ass)
(princ)
(vl-load-com)
(princ)
Accepted solutions (3)
Replies (20)
Message 21 of 21
paullimapa
You’re very welcome and glad to have helped you learn more Autolisp as well…cheers!!!
Paul Li
IT Specialist
@The Office
