COPY STRING FROM VARIABLE TO CLIPBOARD
etilley327KA
etilley327KA
How do I copy a string from my variable to the clipboard for paste?
paullimapa
at AutoCAD command line:
command: (setq a "test string")
command: !a
command: "test string"
select & highlight the above and do Ctrl+C
Command: (startapp"notepad")
then in Notepad do Ctrl+V
Paul Li
IT Specialist
@The Office
Kent1Cooper
Assuming YourVariableName is the variable that contains the string in question, a little Searching reveals several places with this who-would-have-guessed kind of structure:
(vlax-invoke
  (vlax-get
    (vlax-get (setq htmlfile (vlax-create-object "htmlfile")) 'ParentWindow)
    'ClipBoardData
  'SetData
  "Text"
  YourVariableName
That will put it in the clipboard directly from the variable contents, without your needing to pull it from the variable and Ctrl+C copy it.
Kent Cooper, AIA
