Copy quantity of text
pallen9JA6T
pallen9JA6T
Is there a lisp that will copy selected objects and instead of entering a quantity, you would click a text object that specifies the quantity? I want it to paste them in a single row (somewhat like an array with one row and a specified quantity of columns). I've posted a picture of an example. I'm not concerned if the copied objects overlap or not. I would prefer that they are all 2 " apart, but that not critical. I just need them to copy a specified number of times, but I'd like to click a text object to specify the number of copies. Thanks in advance!
ВeekeeCZ
(defun c:CopyArrayPick ( / s n)
  (and (setq s (ssget "_:L"))
       (setq n (car (entsel "\nSelect number: ")))
       (setq n (atoi (cdr (assoc 1 (entget n)))))
       (or (not (zerop n)) (alert "Not a number. Or Mtext formatted."))
       (initcommandversion)
       (command "_.copy" s "" "_non" '(0 0) "_A" n "_non" '(0 0.0508) "")
  (princ)
pallen9JA6T
Works perfect! Thanks so much!
