COPY IN THE SPACE AND PASTE IN WORLD UCS
Im working in my second lisp. Its a very simple series of commands: with some objects rotate in a random space, the idea is to put the ucs with a face of the objects, copy them, return in the world ucs and paste the original objets oriented in the world ucs.
My first lisp was this:
(DEFUN c:CW ( / P1 P2 P3 )
  (SETQ P1 (GETPOINT "\nSelect first UCS point"))
  (SETQ P2 (GETPOINT "\nSelect second UCS point"))
  (SETQ P3 (GETPOINT "\nSelect third UCS point"))
  ;click the 3 ucs points
  		(command "_ucs" "_3p" "_non" P1 "_non" P2 "_non" P3) ; rotate the ucs in the objects plane
		(command "_select" pause ) ; select objects to copy
  		(command "_copyclip" "_p" "" )
		(command "_ucs" "_w") ; return in world ucs
  		(command "_pasteclip" ) ; paste objects in the world ucs
  (PRINC)
but the paste objets is not close to the insert point of the paste command. To solve it i was thinking to use the "copybase" command in this way:
(DEFUN c:CW1 ( / P1 P2 P3 P4 P5 )
  (SETQ P4 (GETPOINT "\nSelect base point of the copy objects"))
  ;click the base point
  		(command "_copybase" "_non" P4 "_p" "" )
   (SETQ P5 (GETPOINT "\nSelect base point to paste the objects"))
  		(command "_pasteclip" "_non" P5 ) ; paste objects in the world ucs
  (PRINC)
but when i paste the objects are invisible and i paste them in a custom position in the layer (also if its asking me the base point in the copybase command.
Im a rookie, i must forgive something, so i will be glad for any help.
ВeekeeCZ
You probably need to translate some points from UCS to WCS or back... read about the (trans) function HERE
i will study it. Thanks
