copy/ extract string from filename
Message 1 of 10
Hello, everyone,
After self-educating lisp and consulating online for a while, I still couldn't find solutions for my questions; refer to attached plan
I want to extract certain text strings from file name and put it in the attributes. For example, the file name is “11175 #5-Station Paris_AR-03 Plans 2150 Nord.dwg” and
  1. if file name contain #1, #2,#3 #4, #5, the attribute “PLANNO” shall be 8001-AR-01(or 02,03,04 05), the last 2 numbers corresponding to the one after #.
  2. if file name contain #6, #7,#8, the attribute “PLANNO” shall be 9001-AR-06(or 07,08).
I have learned a lot from the people and appreciate your constant help.
one another question: how did you get the knowledge on Autolisp, self-educating or in school?
Replies (9)
Message 2 of 10
john.uhden
First of all, I learned a lot by decrypting DCA encrypted AutoLisp files (forerunner of Softdesk and Land Desktop and now Civil 3D).  Then it was mostly trial and error.  Then, after I was getting pretty comfortable, I joined this forum back in the Compuserve days when guys like Terry Dotson, Owen Wengerd, Steve Johnson, Bill Townsend, Stephan Koster, and of course Tony Tanzillo were helping out.  We had a lot of fun attempting to build functions that worked faster than than the next guy's.
As to your file names, might a name actually contain "#1, #2,#3 #4, #5" or just #1, or #2, or #3, etc?  Does the number of digits exceed 2, as in #10 or #13?
If multiple numbers, are they always separated by commas?
John F. Uhden
Message 3 of 10
pbejse
Good question.
Will the value representing  8001 or 9001 change based on a range? or is just these two?
Message 4 of 10
Cool, good to know the legendaries.
Each file name has #1, #2.... respectively. The number will exceed 2
digits till 14.
Thx, John
Message 5 of 10
digits till 14.
Thx, John
Message 6 of 10
pbejse
AR from 8001-AR-01 is based from #5-Station Paris_AR-03 Plans 2150 Nord.dwg ?  it varies depending on the filename? say IR
Message 7 of 10
pbejse
(defun c:demo  (/
                drawingName
                discipline
                prefixCode
                theAttributeBlock
                nameToSetPLANNO)
;;;			pBe July 201			lll
      (if
            (and
                  (= (getvar 'Dwgtitled) 1)
                  (setq drawingName (getvar 'Dwgname))
                  (setq p (vl-string-position 35 drawingName))
                  (> (setq numberAfterSymbol
                                (atoi (substr drawingName
                                              (+ 2 p))))
                     0)
                  (setq discipline
                             (vl-some
                                   '(lambda (d)
                                          (if (vl-string-search
                                                    d
                                                    drawingName)
                                                (substr d 2)))
                                   '("_AR-" "_ST-" "_IR-" "_PL-")))
                  (setq prefixCode
                             (cond
                                   ((<= 1 numberAfterSymbol 5) "8001-")
                                   ((<= 6 numberAfterSymbol 14) "9001-")
                  (setq theAttributeBlock
                             (ssget "_X"
                                    '((0 . "INSERT")
                                      (410 . "~Model")
                                      (66 . 1)
                                      (2 . "FR_ATTR-T*T"))))
                 (progn
                       (setq nameToSetPLANNO
                                  (strcat prefixCode
                                          discipline
                                          (nth (strlen (setq sn   (itoa numberAfterSymbol)))
                                               '(nil "0" ""))
                                          sn))
                       (repeat (setq i (sslength theAttributeBlock))
                             (vl-some
                                   '(lambda (atb)
                                          (if   (equal
                                                      (vla-get-tagstring
                                                            atb)
                                                      "PLANNO")
                                                     (vla-put-textstring
                                                           atb
                                                           nameToSetPLANNO)))
                                   (vlax-invoke
                                         (vlax-ename->vla-object
                                               (ssname
                                                     theAttributeBlock
                                                     (setq i (1- i))))
                                         'GetATtributes)
      (princ)
HTH
Message 8 of 10
the four digits will vary acoording the range; 10-14 will be 10001, and #8 for 1101
thanks
Message 9 of 10
AR will remain.
Message 10 of 10
pbejse
thanks
From this
(setq prefixCode
     (cond
To
(setq prefixCode
     (cond
           ((=  8  numberAfterSymbol) 	"1101-"	)
           ((<= 1  numberAfterSymbol 5) "8001-"	)
	   ((<= 6  numberAfterSymbol 9) "9001-"	)
           ((<= 10  numberAfterSymbol 14) "10001-")
@Anonymous wrote:
AR will remain.
Remove
(setq discipline
     (vl-some
           '(lambda (d)
                            d
                            drawingName)
                        (substr d 2)))
And from this
          (strcat prefixCode
                  discipline
                       '(nil "0" ""))
                  sn))
To
          (strcat prefixCode
                  "AR-"
                       '(nil "0" ""))
                  sn))
HTH
