Copy distance values to past into excel
justinariem
Message 1 of 8
justinariem
How do I automatically copy the value when I use the command distance in autocad into Windows clipboard to paste into excel?
Replies (7)
Message 2 of 8
pbejse
With the use of command Reactors
(if (not *DistToClip*)
    (setq *DistToClip*
	 (vlr-command-reactor
	   "To ClipBoard"
	   '((:vlr-commandEnded . callback:commandendedCancelled)
	     (:vlr-commandCancelled . callback:commandendedCancelled)
(defun callback:commandendedCancelled (Rea Cmd /)
	(if (= (Car Cmd) "MEASUREGEOM")
		(progn
			(vlax-invoke
			  (vlax-get
			    (vlax-get (setq 2ClipB (vlax-create-object "htmlfile"))
				      'ParentWindow
			    ) 'ClipBoardData )  'SetData "Text" (rtos (getvar "distance") 2 )
			(vlax-release-object 2ClipB)
HTH
Message 3 of 8
justinariem
Hi, thanks for the response. I'm a beginner when it comes to these codes. How do I use this? I tried pasting it on the command line then typing Reactors.  nothing happened. Thanks
Message 4 of 8
andkal
Here is a plugin for autocad for this (MSI installation file)
https://apps.autodesk.com/ACD/pl/Detail/Index?id=5859464488561915200&appLang=en&os=Win32_64
and here newer version (plain FAS faile):
http://autolisps.blogspot.com/p/sumarea-sumlen-toclipboard_2.html
• www.autolisps.blogspot.com - Productivity plugins for Autocad and Autocad MEP
• Autodesk AppStore
Message 5 of 8
pbejse
Load the attached file or inlcude it on your startapp suite | acaddoc.lsp or whatever you have setup for autoloading
HTH
Message 6 of 8
justinariem
I tried loading it but the values does not copy to the windows clipboard to paste into excel
Message 7 of 8
pbejse
All you need to do is load the file.
You wanted a command that will work whenever you use the Autocad "Distance" command. and thats what you get.
Unless you wanted it to call an entirely differrent command then you should have stated that from your first post.
Anyway, no point in explaining to you how it works then
BTW: I'm attaching the corrected lisp here
Message 8 of 8
Sea-Haven
A simplified example version pick two points. Credit to Pbe though.
(defun c:test ( / dist)
(setq dist (distance (getpoint "\nPick p1")(getpoint "\nPick p2")))
(vlax-invoke
	(vlax-get
			'ParentWindow
		) 'ClipBoardData )  'SetData "Text" (rtos dist 2 2)
