copy block increase the number inside the text
Hi, I want to copy block and increase the number inside, ex : DB-LP-B4/L1 to DB-LP-B4/L2, DB-LP-B4/L3....I  tried lisp cpi but it didn't work.
Please help me write a lisp.
Kent1Cooper
A Search will probably lead to something already available.  I'm not sure it's exactly what you want, but look at, for example, this.
Kent Cooper, AIA
Thanks for sharing but it didn't work with me.
I also found the right one & share it to whom be needed.
orginial code type oca to copy but I change it to cc for my convenience.
;; free lisp from cadviet.com
;;; this lisp was downloaded from http://www.cadviet.com/forum/topic/34029-can-lisp-danh-so-thu-tu-theo-dang-block-att/
;;;CHUONG TRINH DANH SO THU TU VA COPY TANG DAN
;;;1. Lenh OD: danh so thu tu, tuy chon so bat dau (begin) va so gia (increment) tuy y
;;;2. Lenh OC: copy tang dan tu mot so thu tu co san
;;;3. Lenh oCA: copy tang dan voi doi tuong Attribute Block
;;;Chuong trinh chap nhan cac dinh dang bang so, chu, so va chu ket hop:
;;;1, 2... A, B..., A1, A2..., AB-01, AB-02..., AB-01-C1, AB-01-C2...
;;;Cac chu gioi han trong khoang tu A den Z. Cac so khong han che
;;;Copyright by ssg - www.cadviet.com - December 2008
(defun etype (e) ;;;Entity Type
(cdr (assoc 0 (entget e)))
(defun wtxt (txt p / sty d h) ;;;Write txt on graphic screen, defaul setting
(setq
    sty (getvar "textstyle")
    d (tblsearch "style" sty)
    h (cdr (assoc 40 d))
(if (= h 0) (setq h (cdr (assoc 42 d))))
(entmake
    (list (cons 0 "TEXT") (cons 7 sty) (cons 1 txt) (cons 10 p) (cons 40 h) (assoc 41 d))
(defun incN (n dn / n2 i n1) ;;;Increase number n
(setq
    n2 (itoa (+ dn (atoi n)))
    i (- (strlen n) (strlen n2))
(if (> i 0) (setq n1 (substr n 1 i)) (setq n1 ""))
(strcat n1 n2)
(defun incC (c / i c1 c2) ;;;Increase character c
(setq
    i (strlen c)
    c1 (substr c 1 (- i 1))
    c2 (chr (1+ (ascii (substr c i 1))))
(if (or (= c2 "{") (= c2 "["))
    (progn (command "erase" (entlast) "") (alert "Over character!") (exit))
    (strcat c1 c2)
(defun C:OD( / cn dn c n p) ;;;Make OrDinal number with any format
(setq
    cn (getstring "\nBegin at <1>: " T)
    dn (getint "\nIncrement <1>: ")
(if (not dn) (setq dn 1))
(if (= cn "") (setq cn "1"))
(setq c (vl-string-right-trim "0 1 2 3 4 5 6 7 8 9" cn))
(setq n (vl-string-subst "" c cn))
(if (/= n "") (setq mode 1) (setq mode 0))
(while (setq p (getpoint "\nBase point <exit>: "))
    (wtxt cn p)
    (if (= n "")
        (setq cn (incC cn))
        (setq cn (strcat c (incN (vl-string-subst "" c cn) dn)))
(princ)
(defun C:OC( / e dn p1 cn c n p2 dat) ;;;Make Ordinal number. Copy from template
(setq
    e (car (entsel "\nSelect template text:"))
    p1 (getpoint "\nBase point:")
    cn (cdr (assoc 1 (entget e)))
(setq
(while (setq p2 (getpoint p1 "\nNew point <exit>: "))
    (command "copy" e "" p1 p2)
    (if (= n "")
        (setq cn (incC cn))
    (setq
        dat (entget (entlast))
        dat (subst (cons 1 cn) (assoc 1 dat) dat)
    (entmod dat)
(princ)
(defun C:cc( / e e0 dn p1 cn c n p2 dat) ;;;Make Ordinal number. Copy from Atttribute block
(setq
    e0 (car (entsel "\nSelect attribute block:"))
    e (entnext e0)
(if (/= (etype e) "ATTRIB") (progn (alert "Object is not a Attribute Block!") (exit)))
(setq
(setq
    (command "copy" e0 "" p1 p2)
    (if (= n "")
        (setq cn (incC cn))
    (setq
        dat (entget (entnext (entlast)))
    (entmod dat)
    (command "regen")
(princ)
Hi HeroSy,
Here is something quick and dirty, hope this is what you are looking for:
(defun c:cpinc (/ atrib	    blname    block	i	  inspt
		  newblock  numb      rotation	xscale	  yscale
		  zscale
  (setq block (vlax-ename->vla-object (car (entsel))))
  (setq blname(vla-get-effectivename block)
	xscale (vla-get-XScaleFactor block)
	yscale (vla-get-yScaleFactor block)
	zscale (vla-get-zScaleFactor block)
	rotation (vla-get-rotation block)
  (setq atrib (LM:vl-getattributevalue block "NAMEPLATE"))
  (setq numb (atoi(substr atrib 11)));change this if attribute length is different
  (setq i 1)
  (while
    (setq inspt (getpoint "\nBlock insertion point:"))
    (setq newblock
	   (vla-insertblock ((if (eq (getvar "cvport") 1)
			       vla-get-paperspace
			       vla-get-modelspace
			      (vla-get-ActiveDocument (vlax-get-acad-object))
	     (vlax-3d-point inspt)
	     blname
	     xscale
	     yscale
	     zscale
	     rotation
    (LM:vl-setattributevalue newblock "NAMEPLATE"
(strcat (substr atrib 1 10);change if attribute length is different
(rtos (+ i numb) 2 0))) (setq i (1+ i)) );end while ) ;; Get Attribute Value - Lee Mac ;; Returns the value held by the specified tag within the supplied block, if present. ;; blk - [vla] VLA Block Reference Object ;; tag - [str] Attribute TagString ;; Returns: [str] Attribute value, else nil if tag is not found. (defun LM:vl-getattributevalue ( blk tag ) (setq tag (strcase tag)) (vl-some '(lambda ( att ) (if (= tag (strcase (vla-get-tagstring att))) (vla-get-textstring att))) (vlax-invoke blk 'getattributes) ) ) ;; Set Attribute Value - Lee Mac ;; Sets the value of the first attribute with the given tag found within the block, if present. ;; blk - [vla] VLA Block Reference Object ;; tag - [str] Attribute TagString ;; val - [str] Attribute Value ;; Returns: [str] Attribute value if successful, else nil. (defun LM:vl-setattributevalue ( blk tag val ) (setq tag (strcase tag)) (vl-some '(lambda ( att ) (if (= tag (strcase (vla-get-tagstring att))) (progn (vla-put-textstring att val) val) ) ) (vlax-invoke blk 'getattributes) ) )
 Note that this is going to work only if attribute value is as you described :DB-LP-B4/L1.
dicra
