Copy and Sum in Y axis
Francisco_Melo
Message 1 of 17
Francisco_Melo
Hello, good morning.
I searched but found nothing, is it possible to copy multiply a block with an attribute and add in relation to the last one the distance between them in relation to the Y axis.
Someone can guide or direct me in the right direction.
Thank you in advance.
Replies (16)
Message 2 of 17
pbejse
Starting point for you
(defun c:demo  (/ source)
      (if
            (setq source (car (entsel "\nnSelect Block to copy")))
                 (progn
                       (initcommandversion)
                       (command "._copy" source)
                       (while (> (getvar "CMDACTIVE") 0)
                             (command pause)
                             (princ "\nDo your thing here")
You think you can pick up from this point onwards @Francisco_Melo ?
HTH
Message 3 of 17
Francisco_Melo
Thanks, by the way
It will be difficult but I will try. Shock will not give.😀
Message 4 of 17
ВeekeeCZ
Did you try the COPYM command?
Edit: Well, I missed the 'sum' word.
Message 5 of 17
pbejse
Thanks, by the way
Thats the spirit 👍
Post what you come up with, we will guide you from there.
Message 6 of 17
Sea-Haven
Need a dwg or image to explain more what you want
Message 7 of 17
Francisco_Melo
Here is the block. I want to copy and whenever I want to copy and whenever I put the block it adds the distance in Y with the value of the previous one.
Message 8 of 17
ВeekeeCZ
Simple version to start with... if you have any questions just ask.
(defun c:CopyAltimetric (/ e l y b d p)
  (if (and (setq e (car (entsel "\nSelect 'Altimetric' block: ")))
	   (setq l (entlast))
	   (setq p (cdr (assoc 10 (entget e))))
	   (setq b (getpropertyvalue e "ALT"))
	   (setq d (getvar 'dimzin))
	   (setvar 'dimzin 4)
	   (not (command-s "_.copy" e "" "_non" p))
    (while (setq l (entnext l))
      (if (= "INSERT" (cdr (assoc 0 (entget l))))
	(setpropertyvalue l "ALT" (rtos (/ (+ (* (atof b) 1000) (- (caddr (assoc 10 (entget l))) (cadr p))) 1000) 2 3)))))
  (if d (setvar 'dimzin d))
  (princ)
Message 9 of 17
Francisco_Melo
Thank you. I was completely lost.
Message 10 of 17
pbejse
What happen to trying it out on your own?
Anyway.. hope you learn from this too
(defun c:demo  (/ source _SetGetvalue _copyl)
(Defun _SetGetvalue  (e v)
	(if v (setpropertyvalue
          e "ALT"
          (Rtos (+ (atof (getpropertyvalue e "ALT"))
                      (* 0.001 v)) 2))
    		(getpropertyvalue e "Position/Y")
(if  (and
         (princ "\nSelect Block to copy")
         (setq source (ssget "_+.:S:E:L" '((0 . "INSERT")(66 . 1)(2 . "Altimetric"))))
         (setq p (getpoint "\nSpecify base point:"))
    	(progn
       		(setq plus (_SetGetvalue (setq source (ssname source 0)) nil))
                (while (progn	(prompt "\n[ Press Esc to exit ]")
                                (command "._copy" source "" p pause)
      				(setq p (getvar 'lastpoint))
				(setq plusThis (_SetGetvalue (setq source (entlast)) nil))
				(_SetGetvalue source (abs (- plus plusThis)))
				(setq plus plusThis))
(princ)
HTH
Message 11 of 17
pbejse
	   (setq l (entlast))
... (while (setq l (entnext l))
... (princ) )
Nice idea. 👍
Message 12 of 17
pbejse
Where is your attempt? Do you mind if we have a look?
Message 13 of 17
Francisco_Melo
I'll be honest, I don't understand anything about lisp. I have to take a course to understand, what I'm learning is through comparison of lisp.
(defun c:CSY (/ source)
(if
(progn
(command pause)
(getpropertyvalue "ALT")
(command "._copy")
(setpropertyvalue "ALT" (+ Y
Message 14 of 17
pbejse
Its a start :), Good for you @Francisco_Melo
Having seen the codes posted by myself and @ВeekeeCZ ,  Go figure out whats missing and try to complete the code until it works. 🙂
Work it, Make it, Do it...
Message 15 of 17
ВeekeeCZ
	   (setq l (entlast))
... (princ) )
Nice idea. 👍
Thanks, @pbejse
Actually, I like yours for changing the values each step... but the ESC exit?! Grrrrrrrrrr!
(defun c:CopyAltimetric (/ e b d p)
	   (setvar 'dimzin 4)
    (while (progn
	     (command "._copy" e "" "_non" p "_non" p)
	     (entdel (entlast))
	     (command pause)
	     (if (> (getvar 'cmdactive) 0)
	       (not (command ""))))
      (setpropertyvalue (setq e (entlast)) "ALT" (setq b (rtos (/ (+ (* (atof b) 1000) (- (caddr (assoc 10 (entget e))) (cadr p))) 1000) 2 3)))))
  (princ)
Unfortunately, this way is impossible to retrieve the LASTPOINT sysvar, so no other way around than use the insertion point. I like it better this way anyway. 😎
Message 16 of 17
pbejse
@ВeekeeCZ wrote:
Thanks, @pbejse
I just put one together in haste, should've stayed with the original suggestion using (initcommandversion) though.
Cheers
Message 17 of 17
ВeekeeCZ
@pbejse wrote:... should've stayed with the original suggestion using (initcommandversion) though.
Cheers
Yeah, that's a necessary part of the trick but the real magic, however inefficient, remains, I guess hidden yet unnoticed 😉 No biggie, to be honest, but love how that little trick bends the command to serve to my purpose.
...just like that. Have a great weekend!
