Copy & Paste Existing Hyperlink From One Object to Another
There is a PASTEASHYPERLINK command, but I can't find a "COPYHYPERLINK" command.
I know you can right-click an object with a hyperlink and choose Hyperlink and then choose copy hyperlink, but I want to put this in a Macro so I can;
Pick the object with the existing Hyperlink
and then
Pick the object that I want the Hyperlink attached to.
 - Hundreds of times
It would be useful to me, maybe others as well.
Thanks in advance for any help.
Dan
rkmcswain
You could use something like this to grab the URL from an object.
(setq sel (entsel))
(setq ent (car sel))
(setq obj (vlax-ename->vla-object ent))
(setq hyp (vlax-get obj "Hyperlinks"))
(vlax-for m hyp
  (princ (setq base (strcat "\n " (vlax-get m "URL"))))
...and then here is an example of writing a hyperlink to an object.  Just needs a bit of assembly 🙂
R.K. McSwain     | CADpanacea | on twitter
RK, thank you for the assistance but I'm not sure exactly what to do with this. I saved it as a lisp file, loaded it and it runs and returns the location to where I want the hyperlink to go but it's not saved in memory to use with the PASTEASHYPERLINK command. I think you're really on the right track and I will keep trying to figure out what I can do with it. I definitely appreciate your assistance!
Dan
rkmcswain
If I can find the time soon, I'll return and try and assemble something. (AU Docs are due this week!)
You need the part in the link I provided to take the hyperlink data, and write it to another entity.
Maybe someone else will come along and help out also.
patrick_35
Hi
For example
(defun c:chy(/ doc ent hyp new)
  (setq doc (vla-get-activedocument (vlax-get-acad-object)))
  (vla-startundomark doc)
  (while (setq ent (entsel "\nSelect object with hyperlinks : "))
    (setq hyp (vla-get-hyperlinks (vlax-ename->vla-object (car ent))))
    (if (zerop (vla-get-count hyp))
      (princ "\nNo hyperlinks on this object.")
      (while (setq ent (entsel "\nSelect object to paste hyperlinks : "))
	(setq ent (vla-get-hyperlinks (vlax-ename->vla-object (car ent))))
	(vlax-for lin hyp
	  (setq new (vla-add ent "Patrick_35"))
	  (mapcar '(lambda(x) (vlax-put new x (vlax-get lin x))) '(url urldescription urlnamedlocation))
  (vla-endundomark doc)
  (princ)
braudpat
Hello Patrick
1) Nice routine
For the users, please add the line : (vl-load-com)
2) Why copy the HyperLink to only ONE object !
For me, it would be better to copy to N objects !
Regards, Patrice
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
patrick_35
Thank's Patrick
1) eternal forgot
2) you're right, I simplifies entries
(defun c:chy(/ doc ent hyp new sel)
  (vl-load-com)
  (and (setq ent (entsel "\nSelect object with hyperlinks : "))
      (princ "\nNo hyperlinks on this object")
      (progn
	(princ "\nSelect objects to paste hyperlinks : ")
	(and (ssget)
	  (progn
	    (vlax-for ent (setq sel (vla-get-activeselectionset doc))
	      (vlax-for lin hyp
		(setq new (vla-add (vla-get-hyperlinks ent) "Patrick_35"))
	    (vla-delete sel)
  (princ)
Regards
