Coordinate grids
Hello all
I have a problem with this code:
(defun c:coo () (setvar "cmdecho" 0) (if (not lxg) (setq lxg 100.0)) (if (not lts) (setq lts 2.5)) (if (not llt) (setq llt 10.0)) (setq p nil) (setq p (append p (list (getpoint "\nBottom left corner: ")))) (setq p (append p (list (getpoint (nth 0 p) "\nBottom right corner: ")))) (setq bg (+ (angle (nth 0 p) (nth 1 p)) (/ pi 2))) (setq cp (getpoint (nth 0 p) "\nHeight: ")) (setq dis (distance cp (inters cp (polar cp bg 10.0) (nth 0 p) (nth 1 p) nil))) (setq p (append p (list (polar (nth 1 p) bg dis)))) (setq p (append p (list (polar (nth 0 p) bg dis)))) (setq p (append p (list (nth 0 p)))) (setq abase (getvar "angbase") adir (getvar "angdir")) (setvar "angbase" (/ pi 2)) (setvar "angdir" 1) (setvar "blipmode" 0) (setq xg (getreal (strcat "\nGrid interval <" (rtos lxg 2 0) ">: "))) (if (not xg) (setq xg lxg) (setq lxg xg)) (setq ts (getreal (strcat "\nText height <" (rtos lts 2 2) ">: "))) (if (not ts) (setq ts lts) (setq lts ts)) (setq lt (getreal (strcat "\nTick length <" (rtos llt 2 2) ">: "))) (if (not lt) (setq lt llt) (setq llt lt)) (setq minx (car (nth 0 p)) miny (cadr (nth 0 p)) maxx minx maxy miny) (setq n 1) (repeat 3 (progn (if (< (car (nth n p)) minx) (setq minx (car (nth n p)))) (if (< (cadr (nth n p)) miny) (setq miny (cadr (nth n p)))) (if (> (car (nth n p)) maxx) (setq maxx (car (nth n p)))) (if (> (cadr (nth n p)) maxy) (setq maxy (cadr (nth n p)))) (setq n (1+ n)) ) ) (setq xs (+ xg (* (fix (/ minx xg)) xg)) ys (+ xg (* (fix (/ miny xg)) xg))) ;;;do 'x' grid (bearing = pi/2) (while (<= xs maxx) (setq n 0 plist nil) (repeat 4 ;;;;; find the 2 intersecting grid points with boundary (progn (if (setq ip (inters (list xs miny) (list xs maxy) (nth n p) (nth (1+ n) p))) (setq plist (append plist (list ip))) ) (setq n (1+ n)) ) ) (if (> (cadr (nth 0 plist)) (cadr (nth 1 plist))) (setq p2 (nth 0 plist) p1 (nth 1 plist)) (setq p1 (nth 0 plist) p2 (nth 1 plist)) ) (command "linea" p1 (polar p1 (/ pi 2) lt) "") (command "texto" (polar p1 (/ pi 2 ) (* ts 3.0)) ts (angtos (/ pi 2)) (strcat "E " (rtos xs 2 0) )) (setq xs (+ xs xg)) ) ;;; end while ;;;do 'y' grid (bearing = 0) (while (<= ys maxy) (setq n 0 plist nil phil "done") (repeat 4 ;;;;; find the 2 intersecting grid points with boundary (progn (if (setq ip (inters (list minx ys) (list maxx ys) (nth n p) (nth (1+ n) p))) (setq plist (append plist (list ip))) ) (setq n (1+ n)) ) ) (if (> (car (nth 0 plist)) (car (nth 1 plist))) (setq p2 (nth 0 plist) p1 (nth 1 plist)) (setq p1 (nth 0 plist) p2 (nth 1 plist)) ) ;;;do '+' grid marks (setq sx (car p1) ex (car p2) fx (+ xg (* (fix (/ sx xg)) xg))) (while (<= fx ex) (setq p0 (list fx ys)) (command "linea" (polar p0 pi (/ lt 2.0)) (polar p0 0.0 (/ lt 2.0)) "") (command "linea" (polar p0 (/ pi 2) (/ lt 2.0)) (polar p0 (* pi 1.5) (/ lt 2.0)) "") (setq fx (+ fx xg)) (command "texto" (polar p0 0 (* ts 3.0)) ts (angtos 0) (strcat "N "(rtos ys 2 0) )) ) (setq ys (+ ys xg)) ) ;;; end while (setvar "angbase" abase) (setvar "angdir" adir) (setvar "blipmode" 1) (princ) )
East coordinates are not showed, and I dont know the reason.
Could someone have a look?
