Convert (vlax-get <MLine-object> 'coordinates) to LWPoly entity vertex list
Browning_Zed
Browning_Zed
The function (vlax-get <vla-obj> 'Coordinates) applied to a multiline returns a list of coordinates of the format:
'(1.0 1.0 0.0 4.0 1.0 0.0 4.0 2.0 0.0)
How can I convert it to LWPolyline entity list format:
'((1.0 1.0) (4.0 1.0) (4.0 2.0))
That is, the resulting list must contain sublists of X and Y coordinates, and Z-coordinate must be removed.
Thanks in advance.
ronjonp
Did you do some searching for this? This question has been asked and solved many times.
(defun _2dlst (l / r)
  (while l (setq r (cons (mapcar '+ l '(0 0)) r)) (setq l (cdddr l)))
  (reverse r)
(_2dlst '(1.0 1.0 0.0 4.0 1.0 0.0 4.0 2.0 0.0))
Browning_Zed
Thanks, this is what I need. I tried to look for a solution to this problem, but I did not find it.
Kent1Cooper
Another way, just for fun [using (repeat) instead of (while) because the number of times is known, and (append) instead of (cons) so no reversing is needed]:
(defun XYLfromXYZ (lst)
  (repeat (/ (length lst) 3)
    (setq
      output (append output (list (list (car lst) (cadr lst))))
      lst (cdddr lst)
  output
(setq lst '(1.0 1.0 0.0 4.0 1.0 0.0 4.0 2.0 0.0))
Command: (XYLfromXYZ lst)
And another, using the Mline's entity name without the need to extract the 'Coordinates property:
(mapcar
  '(lambda (x) (cdr (reverse (cdr (reverse x)))))
  (vl-remove-if-not '(lambda (y) (= (car y) 11)) (entget MlineEntityName))
Kent Cooper, AIA
