Hi Mishler,
I’m looking for similar lisp that changes solid (objects created by Solid command) to solid hatch (created by hatch command) but unfortunately couldn’t integrate you have share in post #2 and post #4
Sorry I have poor coding skills.
May you please stick these two bunches of code in one lisp file?
Thank you
Best
Jamal
Jamal,
attached is Jeff Mishler's lisp...
hope that helps
Henrique
Many thanks Henrique for the answer,
Sounds that this lisp file creates also a boundary for the hatch (attached). In may case, there is no need to create boundary for the hatch.
How might this lisp be customized to convert the solid to hatch ONLY (without boundary)?
Best
Jamal
You're welcome, Jamal
"How might this lisp be customized to convert the solid to hatch ONLY (without boundary)?"
the easy way...
after
(vla-delete obj)
add
(vla-delete pline)
hope that helps
Henrique
Perfect! It works fine
Very much appreciated Henrique
Best
Jamal
I tried the LISP routine, I got the message that it loaded successfully but I can't start it (After loading I entered "get_space" and "convert2dsolids" but I get the message "Unknown command".)
What am I doing wrong?
Hi stblb,
after loaded, type cd or (convert2dsolids)
Hope this helps,
Henrique
Hi there,
Is there a way to incorporate this LISP into a command? Or an easier way to load the LISP file each time?
I had to use the LISP a couple of times, but I had to load it each time. Would think there is an easier way.
@quinnahenning wrote:
Hi there,
Hello quinnahenning and welcome to the Autodesk Community!
You may add the .lsp file to your 'Startup Suit' (command 'appload') and the the file will be loaded in all dwg's...
Hope this helps,
Henrique
Henrique,
Thanks for the lisp routine.
It did just what i was looking for.
I have added the code to my extensive acaddoc file, so it loads every time.
Only thing I changed was the "cd" to "c2s".
Not sure why it is called "convert2solids", when it is converting FROM solids.
No worries, it works!
CFK
@c_frankkellogg wrote:
Henrique,
CFK
You're welcome, CFK
But all credits belong to Jeff Mishler, he is the 'convert2solids' author...
Henrique
After I use convert2solids I'm getting
VLAX-GET-ACAD-OBJECT
What should I do?
Thanks a lot
Hello good afternoon someone could send me the routine pleace my email is leo_arq7@hotmail.com greetings from jalisco mexico
