@Anonymous wrote:
Have the same problem but could not find the command MAPEXPORT in acad 2014!
That command wouldn't be in regular AutoCAD. This would be an easy enough thing to make a routine to do, but some questions:
All Points [I assume you're talking about Point entities] in the entire drawing, or would the User select the ones they want?
A Block with or without Attributes?
Keep the Points or delete them [I assume delete if the OP's use of "convert" is applicable for you]?
Blocks inserted at default scale of 1 and rotation of 0, or somehow otherwise?
These commands are the part of verticals Civil, MEP... not vanilla AutoCAD. For that you can try this routine...
http://autocadtips1.com/2012/03/27/autolisp-replace-selected-points-with-block/
