Convert points list to entity name
GeryKnee
GeryKnee
Hello there,
I'm asking for a lisp code that converts a Points [list] object that's obtained by the following command
(setq P2 (entsel "\nSelect Polyline : "))
to [entity name] type
(defun fnOK ( aVar / )
(IF (= (type aVar) 'ENAME)
(princ "OK")
(princ "FAULT !!!!!!!!!!!!!!!!!")
(princ)
(defun fnConvertPointsListToEname ( aVar / RET)
(setq RET aVar)
RET
(defun c:test ( / )
(setq ss (ssget "_X" '((0 . "LWPOLYLINE"))))
(setq P1 (ssname ss 0))
(fnOK P1)
(fnOK (fnConvertPointsListToEname P2))
thanks
Sea-Haven
I am confused maybe some of this will help.
(setq p2 (car (entsel "\nPick a pline "))) ; is entity name
You mention points so do you want a variable for each point in a pline. This can be done.
(setq plent (entsel "\nPick Pline "))
(if plent (setq co-ord (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget (car plent))))))
(princ co-ord)
(setq x 1)
(foreach pt co-ord
(SET (READ (STRCAT "P" (RTOS X 2 0))) PT)
(setq x (1+ x))
(princ p1)
 Just a comment entsel returns 2 items the entity name and pick point, ssname returns an entity name.
