CONVERT OBJECT TO ATTRIBUTE BLOCK
shil143
Message 1 of 8
shil143
 i need to convert multiline text to multiline attributes, Refer Attached DrawingUntitled.png
Replies (7)
Message 2 of 8
-didier-
Bonjour @shil143
You write in AutoLisp forum so I undertand you need a program to do this work
is it OK ? .
You do not want to know how make attributes in a block, that's right ?
Following your responses to these remarks we will respond differently
Amicalement
Éternel débutant.. my site for learning : Programmer dans AutoCAD
DA
Message 3 of 8
devitg
@shil143 Do you mean to be att at each block  all text related to it? could you , please, make , at least , one such block .
I wonder how do you want it to be seen at screen.
An option could be,  make mleader with  a block to show the values.
Please clear it.
Or please make on block , with the need attributes.
Message 4 of 8
shil143
i need to create attrbute block for each box...
EX :   ID
         EASTING
         NORTHING
Above Format
Message 5 of 8
-didier-
Bonjour @shil143
I am afraid I misunderstand the question
why not simply make a block whose attributes are fields
without lisp only native command
amicalement
DA
Message 6 of 8
devitg
@shil143  which one is?
ID
Above Format
Message 7 of 8
CADaSchtroumpf
With your exemple drawing, it's seem to work's...
(vl-load-com)
(defun make_blk ( / )
  (entmake
    '((0 . "BLOCK") (8 . "0") (2 . "TAG_LUMINAIRE") (70 . 2) (4 . "") (8 . "0") (62 . 0) (6 . "ByBlock") (370 . -2) (10 0.0 0.0 0.0))
  (entmake
      (0 . "LWPOLYLINE")
      (100 . "AcDbEntity")
      (67 . 0)
      (410 . "Model")
      (8 . "0")
      (62 . 0)
      (6 . "ByBlock")
      (370 . -2)
      (100 . "AcDbPolyline")
      (90 . 4)
      (70 . 129)
      (43 . 0.0)
      (38 . 0.0)
      (39 . 0.0)
      (10 0.0 0.0)
      (40 . 0.0)
      (41 . 0.0)
      (42 . 0.0)
      (91 . 0)
      (10 0.0 8.95)
      (40 . 0.0)
      (41 . 0.0)
      (42 . 0.0)
      (91 . 0)
      (10 15.45 8.95)
      (40 . 0.0)
      (41 . 0.0)
      (42 . 0.0)
      (91 . 0)
      (10 15.45 0.0)
      (40 . 0.0)
      (41 . 0.0)
      (42 . 0.0)
      (91 . 0)
      (210 0.0 0.0 1.0)
  (entmake
      (0 . "LWPOLYLINE")
      (67 . 0)
      (410 . "Model")
      (8 . "0")
      (62 . 0)
      (6 . "ByBlock")
      (370 . -2)
      (90 . 2)
      (70 . 128)
      (43 . 0.0)
      (38 . 0.0)
      (39 . 0.0)
      (10 0.0 5.1)
      (40 . 0.0)
      (41 . 0.0)
      (42 . 0.0)
      (91 . 0)
      (10 15.45 5.1)
      (40 . 0.0)
      (41 . 0.0)
      (42 . 0.0)
      (91 . 0)
      (210 0.0 0.0 1.0)
  (entmake
      (0 . "LWPOLYLINE")
      (67 . 0)
      (410 . "Model")
      (8 . "0")
      (62 . 0)
      (6 . "ByBlock")
      (370 . -2)
      (90 . 2)
      (70 . 128)
      (43 . 0.0)
      (38 . 0.0)
      (39 . 0.0)
      (10 0.0 2.65)
      (40 . 0.0)
      (41 . 0.0)
      (42 . 0.0)
      (91 . 0)
      (10 15.45 2.65)
      (40 . 0.0)
      (41 . 0.0)
      (42 . 0.0)
      (91 . 0)
      (210 0.0 0.0 1.0)
  (entmake
      (0 . "LWPOLYLINE")
      (67 . 0)
      (410 . "Model")
      (8 . "0")
      (62 . 0)
      (6 . "ByBlock")
      (370 . -2)
      (90 . 2)
      (70 . 128)
      (43 . 0.0)
      (38 . -4.31512e-07)
      (39 . 0.0)
      (10 2.05 5.1)
      (40 . 0.0)
      (41 . 0.0)
      (42 . 0.0)
      (91 . 0)
      (10 2.05 0.0)
      (40 . 0.0)
      (41 . 0.0)
      (42 . 0.0)
      (91 . 0)
      (210 0.0 0.0 1.0)
  (entmake
      (0 . "TEXT")
      (67 . 0)
      (410 . "Model")
      (8 . "0")
      (62 . 0)
      (6 . "ByBlock")
      (370 . -2)
      (100 . "AcDbText")
      (10 0.9 3.15 0.0)
      (40 . 1.25)
      (1 . "E")
      (50 . 0.0)
      (41 . 1.0)
      (51 . 0.0)
      (7 . "ISOCP")
      (71 . 0)
      (72 . 0)
      (11 0.0 0.0 0.0)
      (210 4.50556e-12 -1.10979e-08 1.0)
      (100 . "AcDbText")
      (73 . 0)
  (entmake
      (0 . "TEXT")
      (67 . 0)
      (410 . "Model")
      (8 . "0")
      (62 . 0)
      (6 . "ByBlock")
      (370 . -2)
      (100 . "AcDbText")
      (10 0.95 0.95 0.0)
      (40 . 1.25)
      (1 . "N")
      (50 . 0.0)
      (41 . 1.0)
      (51 . 0.0)
      (7 . "ISOCP")
      (71 . 0)
      (72 . 0)
      (11 0.0 0.0 0.0)
      (100 . "AcDbText")
      (73 . 0)
  (entmake
      (0 . "ATTDEF")
      (67 . 0)
      (410 . "Model")
      (8 . "0")
      (62 . 0)
      (6 . "ByBlock")
      (370 . -2)
      (100 . "AcDbText")
      (10 2.95 6.3 0.0)
      (40 . 1.25)
      (1 . "")
      (50 . 0.0)
      (41 . 1.0)
      (51 . 0.0)
      (7 . "ISOCP")
      (71 . 0)
      (72 . 0)
      (11 0.0 0.0 0.0)
      (210 0.0 0.0 1.0)
      (100 . "AcDbAttributeDefinition")
      (3 . "Luminaire")
      (2 . "ID")
      (70 . 0)
      (73 . 0)
      (74 . 0)
      (280 . 1)
  (entmake
      (0 . "ATTDEF")
      (67 . 0)
      (410 . "Model")
      (8 . "0")
      (62 . 0)
      (6 . "ByBlock")
      (370 . -2)
      (100 . "AcDbText")
      (10 3.0 3.25 0.0)
      (40 . 1.25)
      (1 . "")
      (50 . 0.0)
      (41 . 1.0)
      (51 . 0.0)
      (7 . "ISOCP")
      (71 . 0)
      (72 . 0)
      (11 0.0 0.0 0.0)
      (210 0.0 0.0 1.0)
      (3 . "Coordinate Easting")
      (2 . "EASTING")
      (70 . 0)
      (73 . 0)
      (74 . 0)
      (280 . 1)
  (entmake
      (0 . "ATTDEF")
      (67 . 0)
      (410 . "Model")
      (8 . "0")
      (62 . 0)
      (6 . "ByBlock")
      (370 . -2)
      (100 . "AcDbText")
      (10 3.0 0.95 0.0)
      (40 . 1.25)
      (1 . "")
      (50 . 0.0)
      (41 . 1.0)
      (51 . 0.0)
      (7 . "ISOCP")
      (71 . 0)
      (72 . 0)
      (11 0.0 0.0 0.0)
      (210 0.0 0.0 1.0)
      (3 . "Coordinate Northing")
      (2 . "NORTHING")
      (70 . 0)
      (73 . 0)
      (74 . 0)
      (280 . 1)
  (entmake '((0 . "ENDBLK") (8 . "0") (62 . 0) (6 . "ByBlock") (370 . -2)))
(defun c:AUTOSEL2BLK ( / js delta nw_js n ent obj perim n pt_lst pt_ins val_txt nb ent_sel dxf_ent)
  (setq js (ssget "_X" '((0 . "LWPOLYLINE") (8 . "RD_EX_ST_TEXT"))))
  (cond
    (js
      (setq delta 48.78995 nw_js (ssadd))
      (repeat (setq n (sslength js))
        (setq
          ent (ssname js (setq n (1- n)))
          obj (vlax-ename->vla-object ent)
          perim (vlax-curve-getDistAtParam obj (vlax-curve-getEndParam obj))
        (if (equal perim delta 1E-04)
          (ssadd ent nw_js)
      (cond
        (nw_js
          (repeat (setq n (sslength nw_js))
            (setq
              ent (ssname nw_js (setq n (1- n)))
              pt_lst (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget ent)))
              pt_ins (assoc (apply 'min (mapcar 'car pt_lst)) pt_lst)
              js (ssget "_CP" pt_lst '((8 . "RD_EX_ST_TEXT")))
              val_txt nil
            (cond
              (js
                (if (not (tblsearch "BLOCK" "TAG_LUMINAIRE")) (make_blk))
                (repeat (setq nb (sslength js))
                  (setq
                    ent_sel (ssname js (setq nb (1- nb)))
                    dxf_ent (entget ent_sel)
                  (if (eq (cdr (assoc 0 dxf_ent)) "TEXT")
                    (setq val_txt (cons (cdr (assoc 1 dxf_ent)) val_txt) ang (cdr (assoc 50 dxf_ent)))
                  (entdel ent_sel)
                (entmake
                  (list
                    (cons 0 "INSERT")
                    (cons 100 "AcDbEntity")
                    (assoc 67 dxf_ent)
                    (assoc 410 dxf_ent)
                    (assoc 8 dxf_ent)
                    (cons 100 "AcDbBlockReference")
                    (cons 66 1)
                    (cons 2 "TAG_LUMINAIRE")
                    (cons 10 pt_ins)
                    (cons 41 1.0)
                    (cons 42 1.0)
                    (cons 43 1.0)
                    (cons 50 ang)
                    (cons 210 '(0.0 0.0 1.0))
                (entmake
                  (list
                    (cons 0 "ATTRIB")
                    (cons 67 0)
                    (cons 410 "Model")
                    (cons 8 "RD_EX_ST_TEXT")
                    (cons 100 "AcDbText")
                    (cons 10 (mapcar '+ pt_ins (list (- (* 2.95 (cos ang)) (* 6.3 (sin ang))) (+ (* 2.95 (sin ang)) (* 6.3 (cos ang))))))
                    (cons 40 1.25)
                    (cons 1 (last val_txt))
                    (cons 50  ang)
                    (cons 41 1.0)
                    (cons 51 0.0)
                    (cons 7 "ISOCP")
                    (cons 71 0)
                    (cons 72 0)
                    (cons 11 '(0.0 0.0 0.0))
                    (cons 100 "AcDbAttribute")
                    (cons 2 "ID")
                    (cons 70 0)
                    (cons 73 0)
                    (cons 74 0)
                    (cons 280 1)
                (entmake
                  (list
                    (cons 0 "ATTRIB")
                    (cons 67 0)
                    (cons 410 "Model")
                    (cons 10 (mapcar '+ pt_ins (list (- (* 3.0 (cos ang)) (* 3.25 (sin ang))) (+ (* 3.0 (sin ang)) (* 3.25 (cos ang))))))
                    (cons 40 1.25)
                    (cons 1 (cadddr val_txt))
                    (cons 50  ang)
                    (cons 41 1.0)
                    (cons 51 0.0)
                    (cons 7 "ISOCP")
                    (cons 71 0)
                    (cons 72 0)
                    (cons 2 "EASTING")
                    (cons 70 0)
                    (cons 73 0)
                    (cons 74 0)
                    (cons 280 1)
                (entmake
                  (list
                    (cons 0 "ATTRIB")
                    (cons 67 0)
                    (cons 410 "Model")
                    (cons 10 (mapcar '+ pt_ins (list (- (* 3.0 (cos ang)) (* 0.95 (sin ang))) (+ (* 3.0 (sin ang)) (* 0.95 (cos ang))))))
                    (cons 40 1.25)
                    (cons 1 (caddr val_txt))
                    (cons 50  ang)
                    (cons 41 1.0)
                    (cons 51 0.0)
                    (cons 7 "ISOCP")
                    (cons 71 0)
                    (cons 72 0)
                    (cons 2 "NORTHING")
                    (cons 70 0)
                    (cons 73 0)
                    (cons 74 0)
                    (cons 280 1)
                (entmake (list (cons 0 "SEQEND") (cons 8 "RD_EX_ST_TEXT") (cons 62 0) (cons 6 "ByBlock") (cons 370 -2)))
  (prin1)
Message 8 of 8
shil143
As usual Done............Thanks Boss😉
