Convert Field to Text
Message 1 of 8
I have a autocad 2010 file with a lot of field. I want to convert all of them to text in one time. I have tried some lisp command but it did not work. Could you help me, please? My autocad file is in attached file.
Replies (7)
Message 2 of 8
gdefilo
Hi wwwangeiei,
try the little lisp attached here, should work as expected.
It can remove fields from text or mtext on all text entities in a multiple selection.
I found it in the net some time ago, its author is Joe Burke.
You must rename the extension of the file to .lsp.
Hope this helps,
Giancarlo
Message 3 of 8
vmichl_cs
There is a similar (related) topic with more info:
http://forums.autodesk.com/t5/autocad-2010-2011-2012/convert-field-to-text/m-p/6391117
V.Michl
Message 4 of 8
Thanks, helpful lisp file
Message 5 of 8
 - ROUTINE JUST SAVED ME ABOUT TWO HOURS.
THANKS!
DAJ
Message 6 of 8
ali_ras
Community Visitor
Community Visitor
great 👍
Message 7 of 8
codyC2QXC
Any chance of one that will work on attribute in blocks?
Message 8 of 8
gdefilo
Hi Cody,
have you tried the "burst" command? It is available in the "Express" menu.
It will explode the block, maintaining the value of the attributes, fields included.
Hope this helps,
Giancarlo
