Convert Dynamic Block to Static Block
jtm2020hyo
jtm2020hyo
anyone know if is there any lisp to convert Dynamic Block to Static Block but without rename? I mean only deleting Dynamic Properties for all blocks objects in the drawing.
pendean
Community Legend
Community Legend
jtm2020hyo
all other lisp included in the link above create static block with another name but keep dynamic block with original name
I did not found a method to create only delete dynamic properties from all blocks (static block with origina name).
cadffm
Re think your goal and you will understand that this is impossible.
One Block is a static definition, so it shows everywhere the same content.
(By programming it whould be possible if you have only ONE reference to this block, but if you have multiple blockreferences - all will display the same).
And this is how dynBlocks works, for each variant, AutoCAD create a new (anonym) block.
Sebastian
jtm2020hyo
I just want to delete dynamic properties and keep the name, like use blockeditor , delete dynamic properties then save the block with same name at same drawing, repeat for all others blocks.
... if the dwg breaks is secundary.
RocksterB
Have you seen this post? I had success using "UnDynamic" routine to convert dynamic blocks to static ones.
LISP to explode block and make block again with the same name
sollowyne
THAT DO SOLVE THE PROBLEM.
