Convert CIRCLE to Polyline
Message 1 of 29
Hi Folks,
could you please help me anyone to convert circle to Polyline. I need C# Code to complete this action?
Regards
Alex Andrews.
Replies (28)
Message 21 of 29
ralph.pyka
Observer
Observer
This worked very well.  Thank you for sharing a nice solution.
Message 22 of 29
jbrissonHSYRW
This is what I've done and it has worked very well for me.  I've needed it for adding wipeouts behind circular blocks.
Message 23 of 29
Chris_Rose47VDB
Community Visitor
Community Visitor
Everytime I click on this link it takes me back to the forum main page. Where can I find the actual lsp?
Message 24 of 29
pendean
Community Legend
Community Legend
Actual LISP was posted a few replies later
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/convert-circle-to-polyline/m-p/89959...
Message 25 of 29
Kent1Cooper
@pendean wrote:.....
Thanks for the referral.  I've changed the link in the earlier Message to go there.
This site has lots of broken links like that now....
Kent Cooper, AIA
Message 26 of 29
mehrdad.design9
The easiest way is instead of drawing a circle, draw a polygon with 1000 sides. In CAD it looks like a circle. Then it will be a polyline and for example you can change the globe width of it easily.
Message 27 of 29
Sea-Haven
"draw a polygon with 1000 sides" for me that is not easiest. adds 1000 values to your dwg. It would be easier to just draw a pline using the ARC option and draw 2 arcs, similar to the donut command.
(command "pLINE"  p2 "w" 0.0 0.0 "a" "-180" "l" p5 "a"......     )
Message 28 of 29
Kent1Cooper
[Don't lose sight of the original question, which is not about drawing a circular Polyline, but rather about converting an already-drawn Circle into one.]
Kent Cooper, AIA
Message 29 of 29
_gile
Here's a C# method which creates a polyline matching a circle. It works whatever the circle plane.
public static Polyline CircleToPolyline(Circle circle)
    var normal = circle.Normal;
    var plane = new Plane(Point3d.Origin, circle.Normal);
    var center2d = circle.Center.Convert2d(plane);
    var pt1 = center2d + Vector2d.XAxis * circle.Radius;
    var pt2 = center2d - Vector2d.XAxis * circle.Radius;
    var pline = new Polyline(2);
    pline.AddVertexAt(0, pt1, 1.0, 0.0, 0.0);
    pline.AddVertexAt(1, pt2, 1.0, 0.0, 0.0);
    pline.Closed = true;
    pline.Normal = normal;
    pline.Elevation = circle.Center.TransformBy(Matrix3d.WorldToPlane(plane)).Z; ;
    return pline;
An equivalent LISP routine:
(defun circle2pline (circle / elst normal center vector)
  (if
    (and
      (setq elst (entget circle))
      (= (cdr (assoc 0 elst)) "CIRCLE")
      (setq normal (cdr (assoc 210 elst)))
      (setq center (cdr (assoc 10 elst)))
      (setq vector (list (cdr (assoc 40 elst)) 0.))
     (entmakex
       (list
	 (cons 0 "LWPOLYLINE")
	 (cons 100 "AcDbEntity")
	 (cons 100 "AcDbPolyline")
	 (cons 90 2)
	 (cons 70 1)
	 (cons 38 (caddr center))
	 (cons 10 (mapcar '+ center vector))
	 (cons 42 1.)
	 (cons 10 (mapcar '- center vector))
	 (cons 42 1.)
	 (cons 210 normal)
Gilles Chanteau
GileCAD
GitHub
