Convert an mtext number to inches
Message 1 of 14
Please help, I have a mtext number 0.45 and I would like to click on it and it would become 5-3/8"
I have search all over for an autolisp to do it but found no result.
Thanks for all the help you can offer.
Replies (13)
Message 2 of 14
pbejse
Not sure how  0.45 =  5-3/8" ?  Is this has nothing to do with arithmetic? or just direct Find and Replace string?
Message 3 of 14
It's 0.45'
Approximately equals to 5-3/8"
Message 4 of 14
pbejse
I see. feet to inches then
(rtos (cvunit 0.45 "feet" "inch") 4 3)
Message 5 of 14
I'm sorry I have to rewrite my request to make it clearer.
Let say I have a bunch of mtext and text and in a drawing and they are elevations, 0.45, 0.78 etc......
I would like to convert these to inch and fraction of an inch.
Message 6 of 14
pbejse
Is that just "0.45" or a bigger part of a string like ELEV. + 0.45"?
Message 7 of 14
0.45 is all it shows, no feet mark and it's not an attribute.
Message 8 of 14
pbejse
  (defun c:demo (/ ss i ent)
    (if (setq ss (ssget "_:L" '((0 . "MTEXT,TEXT") (1 . "*#.#*"))))
	 (repeat (setq i (sslength ss))
	   (setq ent (entget (ssname ss (setq i (1- i)))))
	   (if (numberp (Read (setq str (cdr (assoc 1 ent)))))
		(entmod
		  (subst
		    (cons 1 (rtos (cvunit (distof str) "feet" "inch") 4 3))
		    (assoc 1 ent)
		    ent
		  ) ;_ end of subst
		) ;_ end of entmod
	   ) ;_ end of if
	 ) ;_ end of repeat
    ) ;_ end of if
  ) ;_ end of defun
HTH
Message 9 of 14
hak_vz
 Written by someone from SI world. I hope its ok.
(defun C:inch_fract ( / e ent foot inch man res fract fradec i *error*)
(defun *error* () (princ))
  (setq
    e (entsel "\nSelect text object >")
    ent (entget (car e))
    foot (atof(cdr(assoc 1 ent)))
    foot_fix (fix foot)
    rest_foot (- foot foot_fix)
    inch (* rest_foot 12.0)
    man (fix inch)
    res (- inch man)
    fract '(("1" "64")("1" "32")("3" "64")("1" "16")("5" "64")("3" "32")("7" "64")("1" "8")("9" "64")("5" "32")("11" "64")("3" "16")("13" "64")
            ("7" "32")("15" "64")("1" "4")("17" "64")("9" "32")("19" "64")("5" "16")("21" "64")("11" "32") ("23" "64")("3" "8")("25" "64")("13" "32")
            ("27" "64")("7" "16")("29" "64")("15" "32")("31" "64")("1" "2")("33" "64")("17" "32")("35" "64")("9" "16")("37" "64")("19" "32")("39" "64")
            ("5" "8")("41" "64")("21" "32")("43" "64")("11" "16")("45" "64")("23" "32")("47" "64")("3" "4")("49" "64")("25" "32")("51" "64")("13" "16")
            ("53" "64")("27" "32")("55" "64")("7" "8")("57" "64")("29" "32")("59" "64")("15" "16")("61" "64")("31" "32")("63" "64")
    fradec
    (list 0.015625 0.03125 0.046875 0.0625 0.078125 0.09375 0.109375 0.125 0.140625 0.15625 0.171875 0.1875 0.203125 0.21875 0.234375 0.25 0.265625 0.28125 0.296875 0.3125 0.328125 0.34375 0.359375 0.375 0.390625 0.40625 0.421875 0.4375 0.453125 0.46875 0.484375 0.0.5 0.515625 0.53125 0.546875 0.5625 0.578125 0.59375 0.609375 0.625 0.640625 0.65625 0.671875 0.6875 0.703125 0.71875 0.734375 0.75 0.765625 0.78125 0.796875 0.8125 0.828125 0.84375 0.859375 0.875 0.890625 0.90625 0.921875 0.9375 0.953125 0.96875 0.984375 )
    i 0)
    (while (< (nth i fradec) res) (setq i (+ i 1)))
    (setq frac_str (strcat (itoa foot_fix) " " (itoa man) "-" (car(nth i fract)) "/" (cadr(nth i fract)))
          ent (subst (cons 1 frac_str)(assoc 1 ent)  ent)
          ent (entmod ent)
    (princ)
Miljenko Hatlak
Message 10 of 14
john.uhden
Mr. Bond (James I presume):
Having been inspired by @pbejse, I decided to make one that finds all the decimal pieces inside mtexts and convert them from apparent feet to architectural feet and inches.
(defun wcsearch (str match / pos n1 n2 found)
  (setq pos 1 n2 1)
  (while (and (not n1)(not found)(<= pos  (strlen str)))
    (if (wcmatch (substr str pos)(strcat match "*"))
      (progn
        (setq n1 pos)
        (while (not (wcmatch (substr str n1 n2) match))
          (setq n2 (1+ n2))
        (setq found (substr str n1 n2))
      (setq pos (1+ pos))
  found
(defun c:demo2 ( / matches ss i ent old found new)
  (setq matches '("#.##" "##.##" "###.##" "####.##"))
   (if (setq ss (ssget "_:L" '((0 . "MTEXT,TEXT") (1 . "*#.##*"))))
        (setq old (cdr (assoc 1 ent)) new old)
        (while (setq found (car (vl-remove nil (mapcar (function (lambda (x)(wcsearch new x))) matches))))
          (setq new (vl-string-subst (rtos (* 12 (distof found)) 4 3) found new))
        (if (/= old new)(entmod (subst (cons 1 new)(assoc 1 ent) ent)))
NOTES:
The wcsearch function is not built to use wildcards other than #
You can change the matches variable as you see fit for your conditions
Be careful of your setting for DIMZIN.  Mine was 0.
For example, it turned this:
THE ELEVATIONS AT THE FOLLOWING POINTS ARE:
"A" = 22.43
"B" = 8.75
"C" = 133.69
into this:
"A" = 22'-5 1/8"
"B" = 8'-9"
"C" = 133'-8 1/4"
John F. Uhden
Message 11 of 14
pbejse
"A" = 22.43.. "A" = 22'-5 1/8"...
Nice Idea,
I was thinking of simply removing  the precision on the code i posted here
to
(cons 1 (rtos (cvunit (distof str) "feet" "inch") 4 ))
and leave the precision value to  system variable LUPREC for consistency.
Luprec value 2
22.43 -> 22'-5 1/4"
3 22'-5 1/8" 4 22'-5 3/16" 5 22'-5 5/32" ....
HTH
Message 12 of 14
pbejse
Nice Idea,
to
Luprec value 2
22.43 -> 22'-5 1/4"
HTH
- Yesh money penny-
[ at least that is what the user profile shows anyway ]
Message 13 of 14
john.uhden
1st - My routine was written assuming from your example that the existing precision was to the hundredth of a foot.
2nd - LUPREC=3 is to the nearest 1/8 inch, which is very close to a hundredth of a foot (actually 1/96)
3rd - My routine may wreak havoc on any embedded mtext formatting.
John F. Uhden
Message 14 of 14
Thank you everyone, they all worked wonderfully.
