Convert All Text to Field
neam
neam
Hi
Is it possible to change all existing coordinate text content to field position(insertion point of text X,Y,Z)?
pbejse
(defun c:xyz (/ stringUTM vlaObject-UTM objectID-UTM)
  (if (Setq stringUTM (ssget '((0 . "TEXT") (8 . "UTM-TEXT*"))))
    (repeat (setq i (sslength stringUTM))
      (setq vlaObject-UTM
	     (vlax-ename->vla-object
	       (ssname stringUTM (setq i (1- i)))
      (Setq objectID-UTM (itoa (vla-get-objectid vlaObject-UTM)))
      (vla-put-TextString
	vlaObject-UTM
	(strcat	"%<\\AcObjProp Object(%<\\_ObjId "
		objectID-UTM
		">%).InsertionPoint \\f \"%lu2%pt0\">%"
  )(princ)
HTH
neam
Hi dear sir:
Thank you for your attention
pbejse
Glad it helps
Sea-Haven
After looking at your dwg, I may have a different answer for you, its 3 parts the 1st draws rectangs along say a pline path, the rectangs are at a scale matching a title block viewport. Then layouts are auto made matching the location and angle of each rectang. Ok part 2 is I have draw a grid on a viewport, it takes into account a twist in the viewport angle so end up with text like you have.
Let me know if want more info.
neam
Your explanation is exactly correct,
and this is what I do to generate plan and profile sheets with the help of some other Lisp programs.
