Convert a Hatch to a Polyline
timothy_crouse
Message 1 of 17
timothy_crouse
Does anyone have a lisp to convert a hatch to a set of polylines?
I need to convert hatch patterns to polylines which I then apply object lineweights to.  Once that task is complete the set of polylines will be turned into a block.
It's a bit tedious performing this task manually.
Thank in Advance
-Tim C.
Replies (16)
Message 2 of 17
pendean
Community Legend
Community Legend
Do you just need to use a plotstyle table setting for your hatches?
Manually? like you use EXPLODE command then use MPEDIT command, then BLOCK command?
Message 3 of 17
paullimapa
Any particular reason why the objects cannot just stay as LINES after a HATCH pattern is exploded and then you just give those LINES lineweights? What's the purpose of converting them to PLINES?
Paul Li
IT Specialist
@The Office
Message 4 of 17
john.uhden
@timothy_crouse
That's silly.
If you use a .CTB then just change the color of the hatch to a wider pen.
I just tried it and it works.
John F. Uhden
Message 5 of 17
timothy_crouse
Dealing with multiple details of varying scales.  All the objects are in Paperspace.  This is part of working through a process that can be managed / Re-used without customizing the lineweight list or creating a one-off plot configuration file.
I understand there are multiple ways to skin this cat.  Placing details in a viewport is not an option.  When completed these details are to be wrapped up into a block with all objects and annotations.
-Tim
Message 6 of 17
timothy_crouse
The lineweight list does not have the lineweights needed for this task.
Message 7 of 17
paullimapa
what additional lineweights are you referring to?
the ones for LINES as well as PLINES are the same:
Paul Li
IT Specialist
@The Office
Message 8 of 17
Kent1Cooper
@timothy_crouse wrote:
... convert hatch patterns to polylines which I then apply object lineweights to.  ....
Clarify:  You really mean "apply Polyline width to," rather than "object lineweights," which a latter Message says won't do.  [Lineweight and width are not the same thing, and are also both different from thickness.]  Is that right?  If so, the Explode/Mpedit/Block approach could certainly be automated.
[MPEDIT is an Express Tool.  If you want a true AutoCAD command, which presumably would be what a custom command would use, you can use PEDIT and its Multiple option.]
Kent Cooper, AIA
Message 9 of 17
Kent1Cooper
And be aware of the difference between end shapes:
If whatever forms the Hatch boundary is also equally or more wide/weighty, it won't matter.
Kent Cooper, AIA
Message 10 of 17
paullimapa
and at very tight angles plines with width don't turn corners cleanly.
Paul Li
IT Specialist
@The Office
Message 11 of 17
Kent1Cooper
That won't matter in this case -- an Exploded Hatch is always just independent Lines.
Kent Cooper, AIA
Message 12 of 17
paullimapa
that's true as long as the segments are not joined...but once a segment meets at a corner with another and pline width is applied, you can end up with the outer corner not having any width or equal width to the 2 independent pline segments that form that corner angle.
Paul Li
IT Specialist
@The Office
Message 13 of 17
paullimapa
I'm really curious as to how you plan on dealing with the other remaining objects besides HATCHES like LINES, ARCS, TEXTS, DIMENSIONS, LEADER ARROWS and etc. that make up the details. If you are not going to rely on the CTB file to be able to replicate the same weight when printing them in the future, how can you guarantee those other object line widths can be preserved?
Paul Li
IT Specialist
@The Office
Message 14 of 17
timothy_crouse
objects that require a predefined line weight will be converted to a line and have a global width applied.  Plot style that uses the object lineweight will be applied here (to the object).
All the objects that can be assigned line weights from the lightweight list will have those line weights applied via the properties picklist.
The annotation will be set to bylayer
There will be many unique object line weights.  This task has to do with setting up masks for chip-level fabrication.  this is not a typical construction detail.
Exploding hatches and converting the PLines was an option that I wished to explore.  Performing the task manually is a bit labor intensive which is why I was asking if anyone had a lisp.
Other options are being explored as well.  The use of multiple plot configuration files may be a good solution.  It does save a lot of time once default templates are set up.
Best Regards
-Tim C.
Message 15 of 17
paullimapa
Since you're making so many changes to the drawing details, I would keep a copy of the original. Because after these changes you're proposing have been made, it would be very difficult for using these as workable CAD files in the future. One additional caveat with keeping everything in paper space (since you're avoiding the use of vports) is that you will not be able reference this drawing into another since references only recognize objects drawn in model space.
Paul Li
IT Specialist
@The Office
Message 16 of 17
ronjonp
@timothy_crouse Do you have a before and after drawing that you could share? Reading through this thread and I'm still confused as to why this is necessary?
Message 17 of 17
Sea-Haven
Agree with you even images would help.
Are we talking get hatch boundary, explode, get objects within boundary, then make into plines with a width.
