Visual LISP, AutoLISP and General Customization
Continue code after while-loop
3 REPLIES 3
jonas_eek_erikson
301 Views, 3 Replies
I have the following code where after creating a new layer, I loop a function where the user selects an object that get a boundingbox and some property-changes.
What I would like after the user is done selecting objects, is to execute two commands . But when pressing spacebar I get an error message "error: bad argument type: lentityp nil".
(defun C:REVN ( / ss blockID point1 point2 newRevLayer rev rRev obj *error*)
(vl-load-com)
(setq ss (ssget "_X" '((2 . "BL-H-H1"))))
(setq blockID (ssname ss 0))
(setq rRev (getpropertyvalue blockID "REV"))
(setq rev (vl-string-trim " " rRev))
(setq newRevLayer (strcat "REVMARK"rev))
(command "._layer" "_make" newRevLayer "_color" 7 "" "")
(while
(setq obj (vlax-ename->vla-object (car (entsel))))
(vla-getboundingbox obj 'point1 'point2)
(setq point1 (vlax-safearray->list point1))
(setq point2 (vlax-safearray->list point2))
(setq point1 (list (car point1) (cadr point1)))
(setq point2 (list (car point2) (cadr point2)))
(command "._rectang" point1 point2 "")
(command "._pedit" "_last" "w" 2 "")
(command "chprop" "_last" "" "c" 50 "tr" 40 "")
(command "._IsdInsertn" "IN-RIVNING")
(while (> (getvar 'CmdActive) 0) (command pause))
(command "._layer" "_set" 0 "")
3 REPLIES 3
The error occurs when you press space bar and there is no entity selected but your code still wants to process as there is
so perhaps separate it like this
(while (setq en (entsel))
(setq obj (vlax-ename->vla-object (car en)))
Paul Li
IT Specialist
@The Office
Thank you Paul!
You are welcome…cheers!!!
Paul Li
IT Specialist
@The Office
AutoCAD Inside the Factory
