construction lines
construction lines
Message 1 of 24
construction lines
need help, my lisp isn't working.  Thanks
(defun-q c:dz(/ss1)
 (princ"\nErease all xlines:")
 (if(setq ss1(ssget"X"(list(cons 0"XLINE")(con67(if(xyz_is_paper)1 0))))))
  (progn
  (command"erase"ss1)
  (princ(strcat"\Erased "(itoa(sslength ss1))"xlines"))
 );_progn
)'_if
 (princ)
Replies (23)
Message 2 of 24
Kent1Cooper
Welcome to these Forums.
It looks to me as though you have an extra right parenthesis at the end of the longest line.  If removing one doesn't fix it, post your (xyz_is_paper) function [do you know that's loaded?], in case the problem might be in that.
Also, though it may not make a difference, try (defun) rather than the old (defun-q) function [read about that].
Are any Xlines on locked Layers?
Finally, "isn't working" is not really enough information.  In what way does it not work?  Does it do something different from what you expect, or nothing at all?  Is there any error message?  Etc., etc.
Kent Cooper, AIA
Message 3 of 24
when I try to enter it, it says unknown command.
Message 4 of 24
tried it but still get "dz Unknown command "DZ".  Press F1 for help."
Message 5 of 24
hmsilva
Hi agmic,
when formatting the code, you'll need to pay attention at the spaces between functions and arguments...
Was required an extra enter "" to finalize the erase command.
Assuming you have Vladimir Nesterovsky's 'xyz_is_paper' loaded, should work as expected
(defun c:dz ( / ss1)
 (if (setq ss1 (ssget "X" (list (cons 0"XLINE")(cons 67 (if (xyz_is_paper) 1 0)))))
  (progn
  (command "erase" ss1 "")
  (princ (strcat "\Erased " (itoa(sslength ss1)) " xlines"))
 );_progn
);_if
 (princ)
Hope that helps
Henrique
Message 6 of 24
still not working. Anyone have another lisp routine to delete construction lines?
Message 7 of 24
hmsilva
@Anonymous wrote:
still not working.
Do you have Vladimir Nesterovsky's 'xyz_is_paper' loaded?
If not, add this function to 'your' code, and try again...
;;; xyz_is_paper - returns nil for modelspace, T for paperspace
;;;  by Vladimir Nesterovsky
;;; use (cons 67 (if (xyz_is_paper) 1 0)) for ssget "X" of mspace vs. pspace
;;;  note that pspace will get all objects in layouts, not just current
(defun-q xyz_is_paper () (> 2 (getvar "cvport") (getvar "tilemode")))
Henrique
Message 8 of 24
sorry, how do you add this function?  or can i just change the paper to model?
Message 9 of 24
hmsilva
  (progn
 );_progn
);_if
 (princ)
Henrique
Message 10 of 24
Kent1Cooper
Again, what does "not working" mean?  Still an unknown command?  If not, I would guess that it's in the (xyz_is_paper) function, or that function is not loaded.
If you want to delete all Xlines in the current space, try something like:
(defun C:DZ (/ ss1)
  (prompt "\nErase all Xlines:")
  (if (setq ss1 (ssget "_X" (list '(0 . "XLINE") (cons 410 (getvar 'ctab)))))
    (progn
      (princ (strcat "\Erased " (itoa (sslength ss1)) " Xlines"))
    );_progn
  );_if
  (princ)
); defun
If you want to get rid of all Xlines, regardless of where they are, try something like:
(defun C:DZ (/ ss1 n)
  (if (setq ss1 (ssget "_X" '((0 . "XLINE"))))
    (repeat (setq n (sslength ss1))
      (entdel (ssname ss1 (setq n (1- n))))
    ); repeat
  ); if
  (princ)
); defun
Kent Cooper, AIA
Message 11 of 24
should i use the smileyvery-happy after the defun c: ?
Message 12 of 24
Kent1Cooper
Note that while that function, when used in paper space, may get all appropriate objects in all layouts, not just the current one, that only covers the finding of them -- the Erase command will not Erase those that are not in the current layout.  You would need to get into every layout and run the command in each.  If you want to get those in other than the current layout/space, without getting into each one, use something like my version that uses (entdel).
Kent Cooper, AIA
Message 13 of 24
Sorry, the "not working" means that when I load the lisp file and try to use it, autocad gives me dx unknown command"dz"...
Is that better...
Message 14 of 24
Kent1Cooper
No, you should go into your Profile and disable emoticons.  This is a problem that's been pointed out repeatedly around here, since a colon followed by certain letters triggers emoticons, but it's a common element in AutoLISP defined commands that get posted here.  Pick on your user name up top, in the Quick Links area at bottom right choose My Settings, in the Preferences Tab pick on Display, and under Emoticon Type pick None.  Save the change, and thereafter, whenever you are signed in, emoticons of the colon-and-letter variety will not show.
Kent Cooper, AIA
Message 15 of 24
Working in model space, enter the command "dz" autocad says DZ unknown command "dz".  I have tried both of the routines, but neither is working.  (Unkown Command)???
Message 16 of 24
Kent1Cooper
Are the commands loading successfully?  To recap how it should be done, just in case:  Copy the code for one of them and paste it into a plain-text editor like Notepad, and save it into a file called anything you like with a .lsp filetype extension.  In AutoCAD, type AP [or APPLOAD] and navigate to where you saved that file, select it and pick Load, and Close.  It should put a line like this at the Command: prompt line:
WhateverYouCalledIt.lsp successfully loaded.
Kent Cooper, AIA
Message 17 of 24
Lee_Mac
Not too different from those already posted, but try the following:
(defun c:delx ( / i s )
    (if (setq s (ssget "_X" (list '(0 . "XLINE") (if (= 1 (getvar 'cvport)) (cons 410 (getvar 'ctab)) '(410 . "Model")))))
        (repeat (setq i (sslength s)) (entdel (ssname s (setq i (1- i)))))
    (princ)
The command is 'delx'.
Lee
Message 18 of 24
hmsilva
I fully agree with your comments.
I just add Vladimir Nesterovsky's 'xyz_is_paper' with the 'author' comments and explanation, the remaining code was from the 'OP' not mine.
I probably would have written the code using 'entdel', or simply using a 'vla' approach and 'vla-delete'...
Henrique
Message 19 of 24
Kent1Cooper
    ); repeat
  ); if
  (princ)
); defun
So now that I've tried that out a little, I find it has a quirk I can't figure out.  In a drawing with two Paper-Space Layouts, if I draw some Xlines in both of them and some in Model Space, it gets rid of the ones in Model Space and in one of the Layouts, but not in both Layouts.  That seems to be the case whether I run it from Model or Paper Space, and whether, when in a Layout, I'm out in Paper Space or into Model Space through a Viewport.  If in Paper Space, it always dumps those in the current Layout but not the other, but always gets those in Model Space, no matter where I run it from.  It apparently finds the right total number of Xlines, but why it doesn't take them out from one of the Layouts, I couldn't say -- I'd be interested in any theories.
Kent Cooper, AIA
Message 20 of 24
hmsilva
Using entdel, with ssget "_X", if we are in a layout tab, in a dwg with multi layouts, entdel will only delete objects in current layout and model space, if we are in model space, will delete model and first layout objects...
Or we activate each layout and erase ss, or change each entity to a vlaObject and vla-delete, will delete in all layouts...
Henrique
