Ok now remember this is old fashioned goes back to start of Autocad, but is easy to make. Yes people will talk about tool palettes I just find this easier and I am in control not Autocad.
You need to understand how a POP menu works it has sections and in this case we take advantage of the IMAGE section. That does just displays a SLIDE image in the please pick box.
This will be a little long winded.
***MENUGROUP=abcSTDS
***POP20
**CADLIB
[LIBRARY]
[->Stddwgs]
[TRENCH]$I=abcSTDS.TRENCH $I=*
[PIPES]$I=abcSTDS.PIPES $I=*
[PITS]$I=abcSTDS.PITS $I=*
[KERBS]$I=abcSTDS.KERBS $I=*
[ROADX]$I=abcSTDS.ROADX $I=*
[PAVEMENTS]$I=abcSTDS.PAVEMENT $I=*
[MISC]$I=abcSTDS.MISC $I=*
[->IDM dwgs]
[TRENCH]$I=abcSTDS.IDMTRENCH $I=*
[PIPES]$I=abcSTDS.IDMPIPES $I=*
[PITS]$I=abcSTDS.IDMPITS $I=*
[KERBS]$I=abcSTDS.IDMKERBS $I=*
[ROADX]$I=abcSTDS.IDMROADX $I=*
[PAVEMENTS]$I=abcSTDS.IDMPAVEMENT $I=*
This continues for the rest of your menu unitil you get to image section
***image
**PITS
[PITS]
[abcSLD(SD301,PIT DIM SET OUT)]^C^C(openblk "P:/ACADSTDS/CIVIL STANDARDS/CGG301")
[abcSLD(SD302,UNHAUNCHED)]^C^C(openblk "P:/ACADSTDS/CIVIL STANDARDS/CGG302")
[abcSLD(SD303,HAUNCHED)]^C^C(openblk "P:/ACADSTDS/CIVIL STANDARDS/CGG303")
[abcSLD(SD304,MIN WALL THICK)]^C^C(openblk "P:/ACADSTDS/CIVIL STANDARDS/CGG304")
Ok if we look at a line in the image section
[abcSLD(SD305,STEP IRONS)]^C^C(openblk "blablah")
abcsld is a slide library it holds say a 100 slides in one file, you do not need to worry about that at moment.
(SD305,STEP IRONS) SD305 is the name of the slide and "Step irons" is a description
^C^C cancel current command twice at least.
(openblk "blablah") is a lisp program that inserts a block, you would use the following say for a "PIPE1" block.
[(PIPE1,PIPE1)]^C^C(command "-insert" "pipe1" pause 1 1 0)
or a pathed answer
[abcSLD(LeftLaneMustTurnLeftSign,MustTurnLeft)]^c^c-INSERT P:/Autodesk/blocks/trafficsign/LeftLaneMustTurnLeftSign DRAG \1 1 0
a
The menu file I copied out of is 750 lines long and matches this yes I need to recapture should be pits, so I start with stddwgs then select a sub group within and finally choose which block.
Ok now tricky bit but if you do you can have a go at making get stuck make a zip of your mnu and slides and post.
Making a slide is capturing an image of your block, so have block on screen I turn off all junk not required say dims etc. Now for a history lesson slides came in like 40 years ago when computer res was 640x480 not 4k like now, why am i metioning because your slides will be screwed if you use high res. So the quick way around is reduce your Cad screen to like a 1/4 size, get your block do Zoom E then zoom 0.9xp, this is a nice size, the MSLIDE this makes a slide save it to a directory, the directory should be in your support path makes life easier.
Ok to check use VSLIDE should be self explanatory.
Open Notepad and make a start using what I posted as an example. I have been doing this for like 40 years and have a lot of shortcuts latest writes the mnu based on a slide list. You can make like 100 slides in one go using a script or a lisp. But I donot want togo down that path just yet.
Make a mnu with say 5 blocks. Just a comment we had like 500 blocks in our library.
Look at left side of this image, cars had like 20.
