Connectpts - 2016 update
Can anyone help with updating this LISP routine to run in 2016? It connects points with identical descriptions in ascending point #. I do not know the vl-string-search R code for 2016.
Thanks in advance!
;|Platform: AutoCAD Civil 3D
Routine to draw 3dPoly between points with identical descriptions, in ascending Pt# order.
by Jeff Mishler, July 25, 2007. Tested only in C3D2008
(defun c:Connectpts (/ appstr coords desc grps pline point point#s points pt qbldr ss tmpgrp vrsn )
(VL-LOAD-COM)
(setq vrsn (vlax-product-key))
(cond ((vl-string-search "R16.2" vrsn)(setq appstr "3.0"));;2006
((vl-string-search "R19.0" vrsn)(setq appstr "10.0"));;2013
((vl-string-search "R19.1" vrsn)(setq appstr "10.3"));;2014
((vl-string-search "R20.0" vrsn)(setq appstr "10.4"));;2015
(t (alert "This version of C3D not supported!"))
(if (and appstr
(or *acad*
(setq *acad* (vlax-get-acad-object))
(or *AeccApp*
(setq *AeccApp* (vla-getinterfaceobject *acad*
(strcat "AeccXUiLand.AeccApplication." appstr)))
(or *AeccDoc*
(setq *AeccDoc* (vlax-get *AeccApp* 'ActiveDocument))
(setq ss (ssget ":S:E" '((0 . "AECC_COGO_POINT"))))
(progn
(setq pt (vlax-ename->vla-object (ssname ss 0))
desc (vlax-get pt 'RawDescription)
grps (vlax-get *AeccDoc* 'PointGroups)
tmpgrp (vlax-invoke grps 'Add "__TEMP__")
(setq qbldr (vlax-get tmpgrp 'querybuilder))
(vlax-put qbldr 'IncludeRawDescriptions desc)
(if (> (length (setq points (vlax-get tmpgrp 'Points))) 1)
(progn
(setq point#s (vl-sort points '<))
(setq points (vlax-get *AeccDoc* 'Points))
(foreach pt# point#s
(setq point (vlax-invoke points 'Find pt#))
(setq coords (append coords (list (vlax-get point 'Easting)
(vlax-get point 'Northing)
(vlax-get point 'Elevation)
(setq pline (vlax-invoke (vla-get-modelspace *AeccDoc*) 'Add3dPoly coords))
(vla-put-layer pline (vlax-invoke *aeccdoc* 'getvariable "Clayer"))
(vlax-invoke qbldr 'clear)
(vlax-invoke grps 'remove "__TEMP__")
(princ)
Shneuph
Enter (vlax-product-key) into your commandline.  If it doesn't work enter (vl-load-com) then try again.  It'll give you the number to search for.  Obviously, the program should be tested with the new version to be sure it functions properly.
---sig---------------------------------------
'(83 104 110 101 117 112 104 64 71 109 97 105 108 46 99 111 109)
Found the right version info for 2016. Below LISP now tested and works in 2016.
(VL-LOAD-COM)
((vl-string-search "R20.1" vrsn)(setq appstr "10.5"));;2016
(if (and appstr
(or *acad*
(or *AeccApp*
(or *AeccDoc*
(progn
(progn
(princ)
