Confirm selection set
saitoib
saitoib
Hi all.
In the case of VisualLISP, I was able to click on a selection set variable in the watch window during debugging to list its contents.
In the case of VSCode, I cannot seem to display the details.
Is there a solution?
Thank you.
Saitoib
pbejse
You can try setting up a breakpoint and then use Step into ( F11)
Then you can add the variable name on the watch window
You can also "see" the details at DEBUG CONSOLE while in debug mode
HTH
saitoib
@pbejse
Sorry for the late reply.
I can check the contents of the general variables, right?
However, I don't think I can check the contents of the selection set variables.
Saitoib
saitoib
In the example shown, I want to see the contents of SS
Saitoib
