Cond inside cond
Cond inside cond
svucic
Message 1 of 8
Cond inside cond
svucic
I'm wondering if it is possible to use cond inside cond like this :
 (setq add (ssadd) ss (ssadd a))
	    (setq i (sslength ss))
	    (setq temp (ssget "_WP" (_pac (ssname ss (setq i (1- i))))))
            (cond ((/= temp nil)
               		(setq i2 (sslength temp))
			(ssadd (ssname temp (setq i2 (1- i2))) add)
			(setq aadd add)
	   		(setq countobj (sslength aadd))
	          (cond ((= countobj 1)
			(setq aadd add)
			(sssetfirst nil add)
           		(ssget "_I")
		  (cond ((> countobj 1)
			(setq file_handle1 (open "D:\\Data1.txt" "a"))
	   		(setq enname (ssname aadd 0))
	   		(setq enname1 (vlax-ename->vla-object enname))
	   		(setq parbr (vla-get-textstring enname1))
	   		(setq listaprint01(list parbr))
	  		(print listaprint01  file_handle1)
	     (cond ((= temp nil)
			(setq ispis "No parcel number")
	  		 (setq listaprint001 ispis)
	   		 (print listaprint001  file_handle1)
Replies (7)
Message 2 of 8
ВeekeeCZ
I would say "Why not?" But this would be definitely more readable.
(if (setq temp (ssget "_WP" (_pac (ssname ss (setq i (1- i))))))
  (progn ; then
  (progn ; else
But whole code... hmm... would you explain in words what are you trying to achieve?
btw
(if (/= temp nil) ... )
; is the same as
(if temp ... )
(if (= temp nil) ... )
; is the same as
(if (not temp) ... )
Message 3 of 8
svucic
No problem. The code is a modification of a code I found online. It is ment to select all obkects inside a closed polyline. I changed the code a litle bit meanwhile.
(defun c:SWC (/ _pac add ss i temp i2)
  ;; Select Within Curve
  ;; Alan J. Thompson, 03.31.11
  (vl-load-com)
  (defun _pac (e / l v d lst)
    (setq d (- (setq v (/ (setq l (vlax-curve-getDistAtParam e (vlax-curve-getEndParam e))) 100.))))
    (while (< (setq d (+ d v)) l)
      (setq lst (cons (trans (vlax-curve-getPointAtDist e d) 0 1) lst))
(if (setq add (ssadd) ss (ssadd a))
    (progn (repeat (setq i (sslength ss))
               (repeat (setq i2 (sslength temp)) (ssadd (ssname temp (setq i2 (1- i2))) add))
			(setq aadd add)
			(setq aadd add)
           		(ssget "_I")
	     (cond ((= temp nil)
			(setq ispis "No parcel nnumber")
  (princ)
This creates a emty selection set 'add' and selection set 'ss' containing 'a' which is a entity name of the closed polyline.
So, this part selects all objects inside the polyline. When no objects are present it returns 'temp' as nil.
What I'm trying to do with the cond functions is :
-If there are no objects inside the polyline then do this
(cond ((= temp nil)
-If there are objects then count hov many.
			(setq aadd add)
If only one then do this
			(setq aadd add)
           		(ssget "_I")
If more than one than do this
Message 4 of 8
ВeekeeCZ
Well, try this... (untested)
(vl-load-com)
(defun c:SWC (/ _pac add ss i add countobj file)
      (setq lst (cons (trans (vlax-curve-getPointAtDist e d) 0 1) lst))))
  (princ "\nSelect closed curves to select object(s) within: ")
  (if (setq ss  (ssget "_+.:E:S" '((0 . "LWPOLYLINE") (70 . 1))))
    (if (setq add (ssget "_WP" (_pac (ssname ss 0))))
      (if (= 1 (setq i (sslength add)))
	(progn
	  (ssget "_I"))
	(if (setq file (open "D:\\Data1.txt" "a"))
	  (progn
	    (repeat i
	      (print (list (vla-get-textstring (vlax-ename->vla-object (ssname add (setq i (1- i)))))) file))
	    (close file))))
	(progn
	  (print "No parcel number" file)
	  (close file)))))
  (princ)
Message 5 of 8
svucic
I had t modify it a little bit. Now it works when there ar multiple objects inside but crashes when there are no objects. The error is "error: bad argument type: lselsetp nil"
I guess it's because it's expecting a "add" to be a selection set and nil is returned instead.
Had to remove the 'add' from (defun c:SWC (/ _pac ss i countobj file). I also changed
to
(setq ss  (ssadd a))
  ;(setq add (ssadd))
  (if (setq ss  (ssadd a))
	(progn
	  (ssget "_I"))
	      (print (list (vla-get-textstring (vlax-ename->vla-object (ssname add 0)))) file)
	    (close file)))
	(progn
	  (close file)))))
  (princ)
Message 6 of 8
ВeekeeCZ
It's because you have wrong parenthesis when you're working with file.. (trying to open file which wasn't closed before)
;wrong
	  (close file))
; correct
	  (progn  ; do both
	    (close file)))
Little formatted code for making the structure more obvious.
Spoiler
  ;(setq add (ssadd))
	(progn
	  ;; do stuf if ONE ENT is selected
	  (ssget "_I")
	  ;; END OF do stuf if ONE ENT is selected
	(progn
	  ;; do stuf if MORE THAN ONE ent is selected
	    (progn
	      (close file)))
	  ;; END OF do stuf if MORE THAN ONE ent is selected
      (progn
	;; do stuf if NO ent is selected
	  (progn
	    (close file)))
	;; END OF do stuf if NO ent is selected
  (princ)
Message 7 of 8
Kent1Cooper
That can lead you astray.  If a Polyline is closed and linetype generation is enabled for it, the 70-code entry will be (70 . 129), and that filter won't "see" it.
To find closed Polylines both with and without linetype generation enabled:
(ssget [selection modes, if any] '((0 . "LWPOLYLINE") (-4 . "&") (70 . 1)))
(70 . bits):  1 = closed, 128 = linetype generation enabled;
(-4 . "&") is sort of like (logand) -- sees any value with 70 that includes the listed bit [here, 1].
Kent Cooper, AIA
Message 8 of 8
svucic
I'm really grateful and appreciate all the effort. This community is a great place to learn. Everyone is friendly and ready to help. Thank you guys!
