Compare two files in autolisp
Is it possible, in autolisp, to compare two files located in two different places and replace the oldest by the most recent?
For example, the file on my network "R" is my master file. I would like to compare the file on my "C" disk with the one on the "R" disk. If the file's date of the "R" disk is newer than the one's of the "C" disk, then replace the "C" disk file with the "R" disk one.
Ranjit_Singh
Try below code. minimal testing.
(defun c:somefunc  (/ dat1 dat2 filobj fsobj path)
 (setq fsobj (vlax-get-or-create-object "scripting.filesystemobject")
       dat1  (vlax-get (vlax-invoke fsobj 'getfile (setq path (getfiled "Select C: drive file" "c:\\" "txt" 0)))
                       'datelastmodified)
       dat2  (vlax-get (setq filobj (vlax-invoke fsobj 'getfile (getfiled "Select R: drive file" "r:\\" "txt" 0)))
                       'datelastmodified))
 (and (> dat2 dat1) (vlax-invoke filobj 'copy path :vlax-true))
 (vlax-release-object fsobj)
 (princ))
