Compare items from two lists
Message 1 of 14
I have two lists the main and any other list. How to buy the items in a way that if you only have the items from my main list in the other list, return T if not nil.
'(1 3 4 30) ;; main list
(:member '(1 3 4 30)' ( 1 3))
$ T
(:member '(1 3 4 30)' (1 5 6 7))
$ nil
(:member '(1 3 4 30)' (1 4 30))
$ T
(defun :member ( main lst )
  (vl-every '(lambda ( x ) (equal x main)) lst)
I'm going this way, but there should be an easy way to do this without needing a lot of if or cond?
Replies (13)
Message 2 of 14
doaiena
(vl-every '(lambda ( x ) (vl-position x main)) lst)
Message 3 of 14
@doaiena That's right !!
Perfect and sorry to bother !!!
Message 4 of 14
CodeDing
@Anonymous ,
I'm sure that Visual LISP is faster, so doaiena's approach is probably best, but here is the AutoLISP equivalent:
(defun :member (main lst / )
  (apply 'and (mapcar '(lambda (x) (member x main)) lst))
);defun
Best,
~DD
Message 5 of 14
One more doubt!
and to compare if there is a maximum of 2 items in the main list as in the examples.
'(4 2 2 4 ) '(2 3)
$ T ;-> Two item of one type is T
'(4 2 2 4 ) '(4 3)
'(4 2 2 2 5) '(4 5 6 7)
$ T ;-> one of each tbm is T
'(4 2 2 2 4) '(4 5 6 7)
'(4 4 2 2 2 4) '(4 5 6 7)
$  nil ;-> More than two items NIL
'(4 2 2 2 4) '(2 5 6 7)
$  nil ;-> two types but not in the definition list NIL
'(4 2 2 4 3 ) '(4 3)
$ NIL
Message 6 of 14
CodeDing
@Anonymous ,
I don't understand your new criteria..
Can you break it down into a bunch of if / then statements? That would help me visualize it better
Message 7 of 14
doaiena
I think i've got the idea. Is this the result you are looking for @Anonymous ?
(defun test ( lst main / ctr item)
(setq ctr 0)
(while (and lst (< ctr 3))
(setq item (car lst) lst (cdr lst))
(if (vl-position item main) (setq ctr (1+ ctr)))
);while
(if (vl-position ctr (list 1 2)) T nil)
);defun
Message 8 of 14
I am not able to handle this algorithm well.
like this:
If you have a maximum of two items on my main list, return T
'(4 2 2 4 ) '(2 3)
note that I have two 2 on my main list and 2 is present on the secondary (that would be valid! T)
'(4 2 2 4 ) '(4 3)
note that I have two 4 on my main list and 2 is present on the secondary (that would be valid! T)
If I have one of each on my main list (that would be valid! T)
If I have more than two items I would return NIL
if there are more than two I would return NIL
Message 9 of 14
(setq ctr 0)
);while
);defun
Wow !!! where do you learn ??
Exactly!!! Thank you one more time!!
Message 10 of 14
CodeDing
(defun :member (main lst / cnt)
  (setq cnt 0)
  (foreach x main
    (if (member x lst)
      (setq cnt (1+ cnt))
    );if
  );foreach
  (if (< cnt 3) t)
);defun
(defun c:TEST ( / myList)
  (setq myList (list
    '((4 2 2 4) (2 3))
    '((4 2 2 4) (4 3))
    '((4 2 2 2 5) (4 5 6 7))
    '((4 4 2 2 2 4) (4 5 6 7))
    '((4 2 2 4 3) (4 3))
  (foreach x myList
    (terpri)
    (princ (:member (car x) (cadr x)))
  (princ)
Returns:
Command: TEST
T
T
T
nil
nil
Message 11 of 14
doaiena
The problem with checking the counter with (< cnt 3), is that it will return true when 0. Both lists could have no common member, but the function will return true.
Message 12 of 14
CodeDing
WHOOPS!
Great Catch
This would be the fix:
(if (< 0 cnt 3) t)
Message 13 of 14
ronjonp
Just a tiny detail but no need to wrap that check in an IF statement:
(< 0 cnt 3)
Message 14 of 14
ronjonp
@Anonymous
What would you expect to return with a list like this?
'(4 3 2 4 ) '(4 3)
