Command to offset with options specific layer and line type
werner.bianca
werner.bianca
Good morning!
I've been putting together lisps by researching here, mashing things together/trial and error until I'm able to get it to work as I want. But I've been struggling to get this one going (and another one that I'll make a different post for).
This one is about the Offset into a specific layer and linetype. Below is what I have to far.
The idea is to run the command and select which option to go with 1/5.
4 of them go to the same layer but different linetypes. The last one goes into a different layer and linetype by layer.
However I'm having issues with it changing into the linetype I want. Please help
;;;;;;;;;;;;;;;;;;;;;;;;;;;; OFFSET-WIRE to Layer/ LT ;;;;;;;;;;;;;;;;;;;;;;;;;;;;
(defun c:WIRE ()
(setvar "cmdecho" 0)
(command "attdia" "1")
(setq offDist 10) ;(getstring "enter offest distance"))
(setq oldlayer(getvar "clayer")) ;Determine current Layer;
      (setq client
              (getint
                "What Line Offset do you need? [1] 1/W IN, [2] 2/W IN, [3] 3/W IN, [4] 4/W IN, [5] RM"
              (IF (= CLIENT 1)
                  (command "layer" "s" "INSTALL" "")
                  (setq linety "1WIRE")
              (IF (= CLIENT 2)
                  (setq linety "2WIRE")
              (IF (= CLIENT 3)
                  (setq linety "3WIRE")
              (IF (= CLIENT 4)
                  (setq linety "4WIRE")
              (IF (= CLIENT 5)
                  (command "layer" "s" "REMOVE" "")
                  (setq linety "bylayer")
      (print "select line to offset")
      (command "offset" offDist pause pause "")
      (command "chprop" "last" "" "lt" linety "")
(command "layer" "s" oldlayer "") ;Layer back to previous;
(princ)
;;;;;;;;;;;;;;;;;;;;;;;;;;;; END OFFSET-WIRE to Layer/ LT ;;;;;;;;;;;;;;;;;;;;;;;;;;;;
werner.bianca
Accidentally posted twice.
Answer here .
