I've got some simple shortcut commands for changing layers for my dimensions ("1" sets current layer to 2D_DIM, "11" changes object layer to 2D_DIM, "2" sets current layer to 2D_DIM_VERIFY, "22" changes object layer to 2D_DIM_VERIFY). These work great for initial dimensioning, but when we get updated dimensions its a two step procedure the change the dimstyle to/from Annotative to AnnotativeVERIFY and then change the layer.
I would like to create command "111" to change the selected dimension to my Annotative dimstyle and change the layer to 2D_DIM. And then another command "222" to change the selected dimension to my AnnotativeVERIFY dimstyle and change the layer to 2D_DIM_VERIFY.
Everything I've tried does one or the other. Any help would be great.
