Command that displays popup for Reference material text/Notes
Kyle.Pederson
Kyle.Pederson
I'm looking to create a Ribbon command that when clicked will display some reference material particular to our company. Like Company Branch codes for referencing. Currently i just print it off but would like something that would be inside AutoCAD if possible.
All I'm looking for is when you click or type in command name a screen pops open with notes or reference material.
Thanks in Advance,
CodeDing
@Kyle.Pederson ,
How are you storing this 'material'? PDF? Web page? word doc?
It took me FOREVER to find a solution that worked DIRECTLY in the macro command (and allowed for spaces in the path)..
Here's an example that I currently use to open a file location directly from the marco. This should work to perhaps open a PDF or some other document also.
^C^C(command "_.HYPERLINKOPEN" "c:/my folder/my sub folder" "");
Best,
~DD
Kyle.Pederson
Hey @CodeDing
**Correction - It does work, but not in the Tool palette section where i first threw it at**
The File path i have is :  U:\Excel\Branch Code.pdf
when i enter it in the command below i Get "Hyperlink destination cannot be found"
Below is how I've entered it, tried once with the ".pdf" and below with out and still the same issue.
^C^C(command "_.HYPERLINKOPEN" "U:/Excel/Branch Code" "");
Any idea what I'm doing wrong?
CodeDing
@Kyle.Pederson ,
No idea. It works for me..
Add a command by drag / drop onto palette (I renamed mine to 'Open PDF'):
...Edit properties, and for command string I used this:
^C^C(command "_.HYPERLINKOPEN" "c:/users/myName/desktop/myFileName.pdf" "");
 ...Works just fine.
Sea-Haven
You don't have to use a hyperlink if its simple text can use start "notepad" filename or another program like word or pdf via adobe acrobat.
