Command line shortcut for executing a script
chicoseanbrown
chicoseanbrown
What I'm trying to do is pretty basic but it has implications for what can be done in AutoCAD and how, so I think it's worth exploring.  I tend to use the command line, but I often need to draw lines by bearing and distance, so I use the Line by Bearing button from the draw toolbar:
Now, I know I can invoke this like so: L<enter>'BD<enter>.  But I'd rather just type LBD (or something similar) to do that.  Is there a way to make that happen?
A couple ways I could see doing this, but I don't know how, or if it's possible:
1. Assign a command name to that button.
2. Assign a command name to the sequence _LINE 'BD.
3. Write a script file containing _LINE 'BD and assign a command name to execute that script.
Thanks in advance!
paullimapa
Or create a lisp file that's called LBD.lsp
(defun c:LBD ()(vl-cmdf"_.LINE""_'BDEPENDENCYHIGHLIGHT"))
You'll just have to place this lisp file in a folder that's under AutoCAD's Support File Search Path & Trusted Locations
Then use Appload, select Contents on lower right corner & Add LBD.lsp to the Startup Suite.
This way every time you open a drawing AutoCAD will automatically load LBD.lsp so you can use it by entering at the command line: LBD
Paul Li
IT Specialist
@The Office
Sea-Haven
Paullimapa has answered your question but for future reference, a lot of the actual commands do not display when you select from a ribbon, but if you look inside CUI, you can with a little bit of effort find the command and it will have a line like ^c^cBDEPENDENCYHIGHLIGHT,
This is an example of a CIV3D pull down where common used commands have been added to a pop menu, do not have to be in the CIV3D workspace to use.
***MENUGROUP=SURFAL
***POP15
**SURFALIGN
[Surfalign]
[SURFACES]
[Create Surface]^c^c_AeccCreateSurface
[Create Surface from DEM]^c^c_AeccCreateSurfaceGridFromDEM
[Create Surface from TIN]^c^c_AeccCreateSurfaceFromTIN
[->Edit Surface]
[Edit Surface Style...]^c^c_AeccEditSurfaceStyle
[Edit Surface Properties]^c^c_AeccEditSurfaceProperties
[Add Line]^C^C_AeccAddSurfaceLine
[Delete Line]^c^c_AeccDeleteSurfaceLine
Do you use surfaces ? I have a shortcut toolbar,, what Civ3D should have for surface display properties via a toolbar rather than having to go to Toolspace. Contours triangles on/off etc.
