Command line find and replace for Multileader text
Joel_S_Hills
Message 1 of 8
Joel_S_Hills
So far the lisp files I have found wont address the contents of a multileader for find and replace. The only command I found that does it reliably is the FIND (command) but I cant send lisp code to that.
Has anyone made something that works?
Replies (7)
Message 2 of 8
pbejse
Is that just using textstring and/or ContentBlockName?
Message 3 of 8
Kent1Cooper
How 'bout this?  It's unlike FIND in that it just replaces them all, rather than letting you look around and decide for each instance.  So maybe this is just a starting point....
(defun C:MLFR ; = MultiLeader Find/Replace
  (/ old new ss n mldata)
  (setq
    old (getstring T "\nText content to be replaced: ")
    new (getstring T "\nText content to replace it with: ")
  ); setq
  (if (setq ss (ssget "_X" (list '(0 . "MULTILEADER") (cons 304 (strcat "*" old "*")))))
    (repeat (setq n (sslength ss))
      (setq mldata (entget (ssname ss (setq n (1- n)))))
      (entmod
        (subst
          (cons 304 (vl-string-subst new old (cdr (assoc 304 mldata))))
          (assoc 304 mldata)
          mldata
        ); subst
      ); entmod
    ); repeat
  ); if
  (princ)
); defun
AND, I find in quickie trial that it doesn't affect the arrows associated with the Mleader, so if the result changes the length noticeably, the arrows don't attach right.  But if I just tweak the "box" width for it, they fix themselves.
Kent Cooper, AIA
Message 4 of 8
dbhunia
To Find and Replace whole matching Text, try this.......
(defun C:MLTRA ( / Txt_Find Txt_Repl ss) ;; MultiLeader Text Replace All
	(setq Txt_Find (getstring t "\nMultileader Text to Replace: "))
	(setq Txt_Repl (getstring t "\nMultileader Text to Replace With: "))
	(if (setq ss (ssget "_A" (list '(0 . "MULTILEADER") (cons 304 Txt_Find))))
		(foreach Ent (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
			(vla-put-textstring (vlax-ename->vla-object Ent) Txt_Repl)
	(princ)
To Find and Replace a part of matching Text with all occurrences , try this.......
(defun C:MLTRP ( / Txt_Find Txt_Repl ss obj txt_str) ;; MultiLeader Text Replace Part
	(if (setq ss (ssget "_A" (list '(0 . "MULTILEADER") (cons 304 (strcat "*" Txt_Find "*")))))
			(setq txt_str (vla-get-textstring (setq obj (vlax-ename->vla-object Ent))))
			(while (vl-string-search Txt_Find txt_str)
				(setq txt_str (vl-string-subst Txt_Repl Txt_Find txt_str))
			(vla-put-textstring obj txt_str)
	(princ)
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Message 5 of 8
Joel_S_Hills
Thanks, both of you! So far this one is working the closest of what I need,
	(princ)
 One snag, I see is I am trying to also replace text with field formatting, Closest example I see is using this as the new text %<\AcVar Date \f "M/d/yy">%, the field will populate, but just show as ####, is there a way to refresh the field?
Message 6 of 8
dlanorh
A regen or a regenall should do it.
I am not one of the robots you're looking for
Message 7 of 8
Joel_S_Hills
"A regen or a regenall should do it", This dosen't work at all, also closing and reopening the drawing dosent work, but if you double clock the field it will refresh
Message 8 of 8
Joel_S_Hills
originally I was changing textstring, haven't thought about block content
