Command for Load partial .cui file
Good day forum members.
I have a question about user interfaces. Can I externally execute the command "load partial cui file"?
Why I need it: I would like to offer my developed plugins in every language. That means I dont want to change the user interface of the user when installing my plugins, but only to extend my .cui file. is there a possibility ??
Maybe with AutoLISP?
Sea-Haven
Menuload will load a cui. Can be ran from lisp.
Can you write me please the commands? The plugins should be in the dropdown menu and also as a toolbar. Position does not matter. I have no experience with lisp unfortunately.
Sea-Haven
Try this (command "menuload" "P:\\Autodesk\\lisp\\STDS9.mnu")
Perfect, it works thanks a lot!
But once the menu is loaded, there will always be a message from the second time it is already loaded. How can I do that, if the menu entry already exists, the command should be ignored? can you write it me again please?
_Tharwat
Try it this way.
NOTE: Change the name of the menu that fits yours.
(if (vl-catch-all-error-p (vl-catch-all-apply 'vla-item (list (vla-get-menugroups (vlax-get-acad-object)) "Name_of_menu")))
  (command "menuload" "Name_of_menu")
pbejse
..That means I dont want to change the user interface of the user when installing my plugins..
Are you installing via Plug-in Bundle?
