Comma to point decimal separator
Message 1 of 11
I need a quick routine (R14 AutoLisp)
to change the decimal separator from comma
(Italian style) to point:
(setq
qta "123,456"
qta2 (itoa (atoi qta))
qta2 (strcat qta2 "." (substr qta (+ 2 (strlen qta2))))
123.456
Maybe there is something better.
__________________________________
Marc'Antonio Alessi
(strcat "NOT a " (substr (ver) 5 4) " guru.")
Replies (10)
Message 2 of 11
If you are running the Italian localized version of AutoCAD, doesn't
(getreal) handle comma's instead of periods? If not, I believe this should
be something Autodesk needs to look at.
BTW, this is something I cannot check (no Italian AutoCAD ).
R. Robert Bell, MCSE
Xtending the Power
www.acadx.com
"Marc'Antonio Alessi" wrote in message
news:[email protected]...
| (setq
| qta "123,456"
| 123.456
| Marc'Antonio Alessi
Message 3 of 11
Robert, this is my command line (R15 Italian):
Comando: (getreal "Number: ")
Number: 3
3.0
Number: 3.6
3.6
Number: 3,6
È richiesto un valore numerico. (error)
(numeric value requested)
BTW my question was for general purpose
not only to convert from Italian to English form.
In Italy almost everybody use the decimal point
in drawing (English form) for dimensions or other.
But I have several attribute that somebody wrote
in Italian form.
My little routine works good, I only ask if somebody
have something better to use on a lot of strings.
Thanks for your time.
Best regards.
Ciao, Marco.
"R. Robert Bell" ha scritto nel messaggio
> Xtending the Power
> www.acadx.com
Message 4 of 11
Thought that would be what you found. For plain AutoLISP, yours is good (or
you could use this recursion function):
(defun I:Comma->Period (strReal)
(cond
((wcmatch strReal "*#`,*")
(setq
strReal
(strcat
(substr strReal 1 1)
(I:Comma->Period (substr strReal 2))
) ;_ closes strcat
) ;_ closes setq
((wcmatch strReal "`,*")
(setq
strReal
(strcat "." (substr strReal 2))
) ;_ closes setq
(T strReal)
) ;_ closes cond
) ;_ closes defun
Xtending the Power
www.acadx.com
| Number: 3
| 3.0
| Number: 3.6
| 3.6
| Number: 3,6
| in Italian form.
| Best regards.
| Ciao, Marco.
Message 5 of 11
Tanks Robert,
I think this is faster, now I fix for ",n" strings.
(defun Comma2Period ( qta / qta2)
(cond
( (not (setq qta2 (atoi qta))) )
( (zerop qta2) (strcat "." (substr qta 2 )) )
(T (strcat (itoa qta2) "." (substr qta (+ 2 (strlen (itoa qta2))))) )
Ciao
Message 6 of 11
What! You don't want recursion, for recursion's sake?! What would Michael
say?!
Xtending the Power
www.acadx.com
| Tanks Robert,
| (cond
| Ciao
Message 7 of 11
empiric tests:
Comando: test1
2.754
Comando: test2
8.47302
(defun C:TEST1 ( / start stop diff_time)
(setq start (getvar "DATE"))
(repeat 100000
(Comma2Period "123,456")
(terpri)
(setq stop (getvar "DATE"))
(terpri)
(setq diff_time (- stop start))
(princ (* 86400.0 (- diff_time (fix diff_time))))
(princ)
(defun C:TEST2 ( / qf start stop diff_time)
(repeat 100000
(I:Comma->Period "123,456")
(terpri)
(terpri)
(princ)
(cond
(cond
(setq
strReal
(strcat
) ;_ closes strcat
) ;_ closes setq
(setq
strReal
) ;_ closes setq
(T strReal)
) ;_ closes cond
> say?!
Message 8 of 11
I found an error with "0,123" (zero leading string),
now the only problem is in strings with more than
one zero before the comma ("00.123") but I think
this is not a real case.
(cond
( (zerop qta2)
(if (= "0" (substr qta 1 1)) (strcat "." (substr qta 3 )) (strcat "."
(substr qta 2 )))
Marco
Message 9 of 11
Guess my recursive function might work after all? 00,123 is not a problem
for it. Sometimes faster isn't better (don't let Bill Gates know that!) Your
function is nice, though.
Xtending the Power
www.acadx.com
Message 10 of 11
Must I think that "Mr. Bill" code is fast?
Or the best?
Or best and fast?
Or ...
Ciao, Marco.
Message 11 of 11
Or the closest to a monopoly...
Xtending the Power
www.acadx.com
| Or the best?
| Or best and fast?
| Or ...
| Ciao, Marco.
